Old 06-19-2010, 11:41 AM   #16
How many bags of concrete
far's i'm concerned, you aren't, willie,,, then again, we're not from the ' self-absorbed-want-it-now generation '... now you know why leaky bsmt posts get so BORING to me
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 06-19-2010, 11:42 AM   #17
Originally Posted by Squirlgirl View Post
How many bags of concrete will I need to fill a space that is 13.5 feet by 7.75 feet by 4 inches?
Too many. I know I wouldn't want to hand mix that lot whatever it is. At least rent a large mixer or have the concrete delivered. Some rental places have small concrete trailers that will hold quite a large amount of concrete and it's easy to unload. All motor driven. They look like the back of a small concrete truck. You would need a full size pickup to pull it though. Good luck and sorry about some of the responses. Generally a pretty nice bunch. Unfortunately when one posts something a little unfriendly, it just makes it easier for others to do the same.
Mike in Arkansas is offline   Reply With Quote
Old 06-19-2010, 11:59 AM   #18
we're all friendly but answering 4th or 5th grade math problems isn't the purpose of this forum OR any other im-n-s-h-fo !
Old 06-19-2010, 12:39 PM   #19
the Musigician
DangerMouse's Avatar
Originally Posted by thekctermite View Post
Why not just assist the new member with their question like itsreallyconc did, instead of jumping on her? Pretty unimpressive guys.
Agreed.
First off, it would seem the OP has not returned for an answer.
Secondly, sarcasm is seldom truly appreciated as wit.
Thirdly, I would have read past the "163"X93"X4"?" and seen it as inches and then just did the calculations.
Fourthly, some newbies have no idea what the 'search' button is for or how it works, and can barely maneuver a mouse! (Just go meet my Mom if you don't believe me.)
Lastly, forums are full of bored people happy to do the math/searching for a newbie, so I see no problems there. Indeed, most members here that DO help simply do it for the joy of helping others. So let's all just keep doing that!
Po)
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 06-19-2010, 03:42 PM   #20
if you can find some good fill, like stones and old broken up concrete, you can dramatically lower the ammount of mix you need for an area. I recently pured a 1/2 yard pad with less than 1.5 bags, and it should have taken 2.5 (and I even mixed it rich)
another thing to consider is that some concrete places rent out little trailers they fill up with wet mix, kind of like a tiny mixer truck (without the spinning)
forresth is offline   Reply With Quote
Old 06-19-2010, 05:32 PM   #21
we've now arrived at the ridiculous rather'n the sublime
' 13.5 feet by 7.75 feet by 4 inches ' means the critical measurement's 4 INCHES ! ! ! ANY spoil clean fill will negate possible conc strength,,, trying to state a 13.5 cu ft pour w/a volume of conc mix approaching 3cu ft at 4" is not just asinine & outrageous,,, then again, maybe all you wanted was a 1/2" thick slab can't even imagine such placement being permanent OR possible !
who sez the op hasn't returned ? you really think she wuz a ' hit & run ' poster ? if someone can't read a bag of conc mix & do a little arithmetic, its a safe bet pulling a u-cart full of fresh mud's not going to happen
notice jomama took the w/e off
The Following User Says Thank You to itsreallyconc For This Useful Post:
Willie T (06-20-2010)
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Bags of concrete left out in the weather ovahimba Building & Construction 3 10-30-2009 09:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
