How To Make White Mortar For Brick Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-25-2009, 01:53 PM   #1
how to make white mortar for brick wall
Good afternoon, I will be building a small brick wall in my front yard and need to find a way to make the mortar match the existing brick veneer of the house. This new wall will be 27" high and 12' long, two bricks wide. It is non-load-bearing, sits on a 4" poured concrete footing (in Georgia where there is no frost line), and it won't be retaining any soil; it's purely decorative and the foundation is omre than sufficient. I don't want it to crack and fall apart, but its about a simple a project as brick gets.
Anyway, the mortar on my 40-year-old house is rather white or sandy-colored and miles away from the gray test mix I made of the mortar I bought (one part Quikrete type N masonry cement to 3 parts general purpose sand). Can I add powdered lime to make the mix whiter? Will increasing the sand content to a 4:1 or 5:1 mix cause huge adverse effects on a small, decorative wall?
Thanks for any advice!!
nhertel is offline   Reply With Quote
Old 05-25-2009, 03:03 PM   #2
Rewards Points: 1,232
Lime will make it lighter, but you should probably use white cement.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 05-26-2009, 09:22 AM   #3
scar's right as usual most masonary supply yards around atl have white cement,,, i like usa block on 41 just up from the big chicken even tho home depot owns it but at least they kept the same guys ( so far everyone speaks english yet ),,, they'll also have white sand !
its FAR easier to color white mortar than try to whiten the yellow mortar so prevalent in our area ( e cobb )
yesitsconcrete is offline   Reply With Quote
Tags
brick , brick wall , lime , masonry , mortar
Mortar bed removal from block wall Douger_F Building & Construction 8 04-15-2009 08:47 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 11:24 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
cannot make cabinets flush with wall barcoo Carpentry 3 07-20-2006 11:58 PM
