-   -   how to make white mortar for brick wall (http://www.diychatroom.com/f19/how-make-white-mortar-brick-wall-45217/)
nhertel 05-25-2009 12:53 PM
Good afternoon, I will be building a small brick wall in my front yard and need to find a way to make the mortar match the existing brick veneer of the house. This new wall will be 27" high and 12' long, two bricks wide. It is non-load-bearing, sits on a 4" poured concrete footing (in Georgia where there is no frost line), and it won't be retaining any soil; it's purely decorative and the foundation is omre than sufficient. I don't want it to crack and fall apart, but its about a simple a project as brick gets.
Anyway, the mortar on my 40-year-old house is rather white or sandy-colored and miles away from the gray test mix I made of the mortar I bought (one part Quikrete type N masonry cement to 3 parts general purpose sand). Can I add powdered lime to make the mix whiter? Will increasing the sand content to a 4:1 or 5:1 mix cause huge adverse effects on a small, decorative wall?
Thanks for any advice!!
Tscarborough 05-25-2009 02:03 PM
Lime will make it lighter, but you should probably use white cement.
yesitsconcrete 05-26-2009 08:22 AM
scar's right as usual :thumbup: most masonary supply yards around atl have white cement,,, i like usa block on 41 just up from the big chicken even tho home depot owns it :furious: but at least they kept the same guys :yes: ( so far everyone speaks english yet ),,, they'll also have white sand !
its FAR easier to color white mortar than try to whiten the yellow mortar so prevalent in our area ( e cobb )
