How To Make A Walk Out Basement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-20-2009, 10:32 AM   #1
How to make a walk out basement?
We have a house with a full window in the basement. The builder did not make it a walkout. Not sure why b/c there is enough room to have made a walkout. We were thinking of calling a contractor to see if they can make the basement a walkout now. I know that it would involve cutting away some of the concrete. I just am not sure if it can be done. Obviously cost is a huge consideration and we can evaluate that after calling a contractor, just not sure if it is possible so I thought I would ask before calling a contractor. Thanks,
kimmieandtco is offline   Reply With Quote
Old 04-20-2009, 10:44 AM   #2
Concrete & Masonry
Rewards Points: 636
If your in a region that gets any kind of frost in the ground, you will need additional foundation depth. The most cost effective & feasible way to do this IMO is to add on a small addition in this area with proper frost walls, rather than under-pin the existing foundation.
jomama45 is offline   Reply With Quote
Old 04-20-2009, 11:04 AM   #3
Structural Engineer
Great idea. I will add that I have seen additions like this simply be for a staircase on that side of the home. The one I'm thinking of had the stairs access the kitchen area of the first floor of the home. Then the landing area of those stairs at the basement was large enough for a simple mud room. It was a great addition to this home because because there was no access from the first floor of the home to the back yard other than from stairs on a small deck that was only accessed from the master bed room.
wildcat is offline   Reply With Quote
Old 04-20-2009, 12:30 PM   #4
Walk out - level?
Or stairs that you will have to walk up?
If there isn't any dirt in front of that window then the foundation should already extend down past the frost line. If ther eis dirt there then most likely the foundation does not extend down far enough past the frost line once you dig out
One house in the basement they put a window in when a door was required. They simply cut the concrete & put a door in (4-5 steps to walk up). That was 30 years ago, not sure if they (builder) verified the foundation 1st
Old 04-20-2009, 12:39 PM   #5
Registered User
Rewards Points: 526
I'm confused by the replies.
You have a window in the basement, you want to change it into a door, to walk out of?
Is that correct, if not please explain, thank you. Be safe, GBAR
Old 04-20-2009, 05:48 PM   #6
I realize now that I was not as clear as I should have been. We have a window in the basement. There is no door and I want to put a door in. But there is concrete under the window. It seems that there is plenty of room to have cut out the foundation and put in a door in that area. Meaning, there would be no steps necessary. From the outside of the house you would just walk into the basement. So we would need to cut through the foundation right below the window to make the room for the door. The foundation then continues deeper than where the door would lie and that is below the frost line. The property basically drops off in the back of the house versus the front of the house. So it seems there was ample room to make a walkout but for some reason they didn't. So that is what we want to do now. Does that make sense?
Old 04-20-2009, 05:55 PM   #7
Concrete & Masonry
Rewards Points: 636
As long as your saying the siding (outside) goes all the way down to the basement floor level, it should be a fairly simple job.
Old 04-20-2009, 05:55 PM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,714
Ayuh,... It should be a piece of cake to cut out a bigger hole,+ install a Door...
Call your contractor...
Bondo is online now   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Basement Reno - Laundry, Bathroom mostr Building & Construction 2 03-02-2009 09:50 PM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 06:38 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
