Old 04-13-2009, 12:29 PM   #1
Default How to make make curves with sheetrock?
I'm designing a drop ceiling in my kitchen over the bar and plan building it using mostly sheetrock, 2x4s, and plywood. There are areas in the design in which I would like to have semi-rounded curves along the sides. I'm wanting the surface to be mostly sheetrock, but not sure what is typically used in contruction projects, as most drywall seems unbendable. I've thought of using a thin wood panel and perhaps after it was mounted... covering it with paper, thus texuring it afterwards with thinned drywall compound. Is there a better way perhaps to achieving what I speaking of? Any tips would be greatly appreciated. Thank you for reading. Charles
fredonian is offline   Reply With Quote
Old 04-13-2009, 12:37 PM   #2
BIGRED
They do make thin drywall for what you are talking about. About 1/4" I think. They may even have thinner rock, I'm not sure. A lot of times I have seen good rockers score the face of the panel in as narrow increments as 1" and glue and screw the panel to the framing, but talk to some drywall outfits around you. They probably have even more ideas that could work better for you.
Grampa Bud is offline   Reply With Quote
Old 04-13-2009, 12:46 PM   #3
General Contractor
HWConstruction's Avatar
Default Bendable rock
As Gramps said, 1/4" bendable drywall. You will have to get it at a drywall supply house. The box stores don't carry it. Also as said it needs to be scored and broken to achieve a tight arc.
HWConstruction is offline   Reply With Quote
Old 04-13-2009, 01:23 PM   #4
Drywall contractor
"Bendable" will be probably be easiest to work with. I haven't used it. Regular 1/4" will work if the radius isn't TOO severe. Getting the drywall to curve is easier if you wet it. Not saturate, but pretty damp. Then work it around the radius. Use adhesive and as few fasteners as possible as they will tend to make the drywall break. Fasten the ends away from the actual radius. Make sure there are plenty of framing members for adhesive and for the drywall to conform to (2"x4" s every 3 or 4 inches in the radius). On new construction we used to take the 1/4" rock and lay it on the basement floor for a couple of days before using it. The "fresh" concrete would get just about the right amount of moisture in the board. Sometimes we would wet the floor first to aid our cause. If that was not an option, cut the strips and lean against a wall. Take a bucket of water and a sponge and wipe down the strips with water. Allow to stand overnight and they'll bow on their own to begin forming your curve. Repeat the process if needed. I personally have never scored drywall to get it to bend. I have heard of using 1/4" masonite on a radius if it's too tight for drywall to bend around. Never had to do it though....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-14-2009, 03:08 PM   #5
Thanks fellas! Not just a common thanks....but a REAL thanks for your input! Little do some of you know just how much your input saves us money and from embarking into disasterous efforts. Charles
Old 04-14-2009, 05:35 PM   #6
Drywall contractor
I admire those who are willing to attempt to do the work themselves. Just be willing to accept (admit) your limitations and keep it safe. Even the pros know when to call another pro....
Old 04-14-2009, 06:04 PM   #7
Power Gen/RS Engineer
I built a curved wall several years ago and I can certainly offer some advice from my experience.
Framing: Double up your studs. I'm my case (about R=5ft), I framed at 8" o.c. instead of 16".
Sheetrock: Buy 1/4." In spite of what was said, my local Menard's does sell that thickness.
Installation: You do NOT need to score it nor would I advise doing so. To make the rock bendable, I used a spray bottle filled with water for this. Spray the outside radius (i.e. the convex side) until damp. At that point, you can form it immediately.
Start at one end, begin fastening and move toward the other. Since you have doubled up your framing however, only fasten the drywall EVERY OTHER STUD. If you fasten more often, the sheet rock will lose it's smooth curve and start taking on a segmented surface.
In my instance, I built the wall using two layers to achieve 1/2" thickness where the curve met the adjoining straight wall.
Good luck!
Think of how dumb the average person is. Now remember that half of all people are dumber than that-George Carlin
BigJimmy is offline   Reply With Quote
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to create a radius with our Random Orbit Sander. To create a radius on my piece of stock here, I am going to turn the sander on and as I move it back and forth I am... Read More »
Hi, I'm Frank Pope of FBI guitars an behalf of Expert Village to talk to you guys about how to build your own guitar. Now, I'm going to talk to you about another thing you need to consider before you start building your guitar. That is what radius on the... Read More »
Before I go ahead and close the ends of the lampshade, I'm going to remove any markings that are on the plastic that either got there by any kind of smudging or any other type of small markings, or by accident, and to do this I use some alcohol on a... Read More »
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. All panels are fastened through the front lip with a minimum of four fasteners per panel. Building codes or special conditions may require more, please... Read More »
In this clip, I'd like to talk about the cove. The cove is this area behind me. It's a curved surface that curves away from the shooting side of the studio up into the wall so that there's no seam. These can be made out of - well, I've made simple ones... Read More »
How to make room for humidifier zunk HVAC 4 02-24-2009 07:00 AM
sheetrock TonyD Painting 6 02-14-2007 12:07 AM
Need Sheetrock repair advice Giterdone Carpentry 6 02-03-2007 10:38 AM
sheetrock cieling? old house jamesdart General Discussion 4 10-09-2006 05:36 PM
sheetrock feb General Discussion 7 10-02-2005 10:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
