-   -   How to Lower Basement Bathroom Ceiling (http://www.diychatroom.com/f19/how-lower-basement-bathroom-ceiling-96830/)
JDC4NU 02-28-2011 01:29 PM
I am finishing my basement and have framed in the bathroom. I have a question about the ceiling. I have a pipe running across the length of ceiling in the new bathroom. The pipe is from the sump pump, taking it to the outside. The pipe hangs approximately 4.5 inches below the floor joists and about a foot away from the new wall.
I could build a soffit to enclose the pipe but would prefer a clean looking ceiling in this instance. The bathroom is 5' x 8' and the pipe runs along the 8' length. The joists run perpendicular to the pipe. The floor joists are 9' tall so height is not a concern.
I have some 2x6's that went unused in the framing part of the project. My idea was to attach some verticle 2x4's to the joists and then then attach the 2x6's therefore just extending the floor joists lower.
Is this a reasonable solution to maintain a clean ceiling rather than just boxing in the pipe? Or is there something wrong with this idea that I have not thought of?
kboyz 02-28-2011 05:36 PM
What about a drop ceilin? Clean look and access to the pipe just in case.
Wildie 02-28-2011 05:46 PM
You could use the 2X6`s to form a ledger board around the perimeter (at the 8 foot level) and then install 2X6 ceiling joists between the ledgers.
Then install drywall in the usual manner,
High Gear 03-01-2011 12:19 AM
You could reroute that pipe outside the bath maybe and enclose in a sofit.
A drop ceiling and a bath probably not a good idea ( moisture ).
