How Long To Wait For Concrete To Cure? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2012, 01:45 PM   #1
Rewards Points: 89
How long to wait for concrete to cure?
My basement slab was just repoured (after being removed and a perimeter drainage system was added), and I have a few questions:
1. Should I cover it with plastic and mist it twice daily?
2. How long should I wait before putting down 1" sheet foam, tape the seams, and then seal it to the wall with spray foam? I then plan on putting plywood down, and then tapconing it to the floor, then build my interior walls (i.e., the Mike Holmes method:
http://www.theglobeandmail.com/life/home-and-garden/real-estate/the-star-of-holmes-on-homes-answers-your-questions-in-this-blog/article1107033/?page=all ).
The concrete slab is up to 8" thick in some parts, but is mainly 4" thick in most parts. There is a 15-20 mil vapor barrier between the earth/aggregate and the concrete.
My contractor told me to mist it daily, but he didn't know about how to do it when the sheet foam was added to the mix.
Any advice is appreciated.
Thanks,
toddmanqa
toddmanqa is offline   Reply With Quote
Old 07-27-2012, 02:48 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,110
Is this exposed?
Typically, your going to be at a majority of your strength in 7 days....28 days for full strength.....
The plastic and misting just slows down the drying so as to reduce minor cracking.....if expansion joints were properly done...you should not have any significant cracking.
Remember....ALL concrete cracks....some just take longer than others....some cracks more than others.
I would cover with plastic....and keep it damp....you can tell by the color...dark gray is damp....light gray is dry......chances are with plastic down, the center will stay damp....just wet down the edges...they dry first. You basically want the whole thing to dry at the same rate.
I would wait a week after you pull up the plastic before you put down the foam.....it will tend to hold in the moisture....you don't want excessive moisture down there...
So.....cover for a week....then expose it for a week to allow for more drying....then go for it.
Concrete does not like to be rushed. AMHIK
I would wait at least a week before drilling any holes....
ddawg16 is online now   Reply With Quote
Old 07-27-2012, 03:01 PM   #3
Rewards Points: 89
Exposed response
The basement has three 33" x 12" windows, which are open, and a five foot by five foot opening in one wall that was being used to bring materials in/out.
So, it is partially exposed to the outside.
Regards,
toddmanqa
Old 07-27-2012, 03:46 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
misting is always a good thing, helps the concrete to slow cure and to develop its strength and helps to prevent spider cracks (small cracks in various directions). as ddawg said 7 days is normal for curing the concrete.
good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-27-2012, 07:44 PM   #5
Concrete & Masonry
Rewards Points: 636
Basements are generally damp enough this time of year, and the earth should be relatively cold, so I wouldn't worry too much in your case, especially considering you'll be drilling a ton of holes, gluing on it, and covering it anyways. A typical basement floor does little more than provide a hard sweepable surface and protect the vapor barrier from damage, it doesn't need to achieve a high compressive strength.........
jomama45 is offline   Reply With Quote
Old 07-29-2012, 12:17 AM   #6
Registered User
Rewards Points: 526
No plastic over it to dry, not cure: http://www.cement.org/tech/cct_curing_drying.asp
4 weeks, with foam and depending on the finish floor covering, Fig. #4; http://www.stegoindustries.com/docs/...0coverings.pdf
Gary
Old 07-29-2012, 10:23 AM   #7
Licensed Engineer
Rewards Points: 175
Gary
+1
You only need to cover the concrete with plastic and mist it if it was poured outdoors on the hottest days of summer. This is an indoor slab so no plastic is required.
Let it cure the full 28 days before covering it with anything else.
MI-Roger is offline   Reply With Quote
How long do I need to wait to shingle if my felt has been rained on? J S Machine Roofing/Siding 3 03-19-2011 11:17 PM
How Long Do We Have? Docfletcher Off Topic 19 05-01-2010 11:02 AM
Concrete cure timchi29 Remodeling 4 11-07-2008 02:45 PM
How long should A/C take to cool house? AllGoNoShow HVAC 2 06-17-2007 07:01 PM
Long range HVAC planning. dalesd HVAC 2 02-23-2006 12:37 PM
