#1 |
How long until my 2x12s sag?
I just installed 2x12x20' southern pine boards in my hip roof garage as joists, with no support above them or below them. Other than a non-insulated garage door, the joists will have virtually no load. Can anyone tell me if the joists will sag over time? Thanks.
Jesse PS. They are attached to the wall studs with joist hangers and the rafters on top with mending plates. Thanks again. |
#2 |
You are within the limits for ceiling joists with minimal load in the span tables. You could use 2x8 24 inch on center and still be ok. The table says 2x10 southern pine will go 20ft at at a load that would assume a drywall ceiling. The key function of the joist is to prevent spreading of the walls. You really should have the joist nailed to the rafters. Hard to say mending plates are not a rated to perform this function... but it may work. I suspect you would see the joist hanger pulling away from the walls if you had a issue.
#3 |
Any joist will sag, even under its own weight and regardless of the span; it's a question of how much deflection you are prepared to tolerate. For domestic floors, your local code will probably put a limit on the deflection; typically it's about 0.003 of the span. For unloaded ceiling joists in a garage, the deflection allowance will obviously be greater.
What is more of an issue here is what bill01 has pointed out - the fixing between the ceiling joists and rafters. As he stated, strictly,they should be nailed together (or bolted). If your plates are big enough, though, you should be OK. |
#4 | |
How long until my 2x12s sag?Quote:
Jesse |
#5 |
The math gets complex very fast when you want to calculate the actual deflections. The tables just make sure you do no exceed a value but do not tell the actual value just that you are less. The common one to use is x/240 so in your case you have 20ft which 20/240 = .083 ft or about 1 inch. But that would assume you use 2x8 or 2x10. With 2x12 it will be less. I bet about 1/2 inch.
If you mean hurricane ties those won't do the job either. The actual force is also a complex calculation that is dependent on many thing like the slope of the roof and the snow loads. I would bet you have 500lbs of force you have to transfer from the top of the wall to the joist. If you were going to nail it they would want 5 3 inch nails. When you start using using metal side plates especially when they meet at a angle you need to be a structural engineer to calculate if they will work. They do make long coils of steel strapping that you can run the complete length to hold the rafter ends together. You could then not worry about the joist. I think you can do them every other joist rather than everyone. |
#6 |
There are equations to work out the actual deflection of beams, and as a matter of interest I tried it on yours. If your span is 270"; your joists are @16" c/s; they are only supporting their own weight and a plasterboard ceiling; and your timber is 1,000 psi grade, then the natural deflection (sag) will be about 0.2 inches at maximum (at midspan), which is nothing. The natural warp/twist of the timber will probably be more than this.
Over time, the timber will gradually sag a litle more because timber is subject to long-term creep under load, but it still won't add up to much. As pointed out before, your main concern is to make sure that the joists are firmly fixed to the rafters.Without an adquate fixing, the rafters will tend to push the walls out of plumb, and then deflection of the ceiling joists would be the least of your worries! |
#7 | |
#8 | |
Jesse |
#9 |
did you install ceiling joists, or is this a cathedral ceiling?
Gary "You get what you pay for, and sometimes free costs more!" |
#10 |
How long until my 2x12s sag? |
#11 |
Here is a pic I snapped yesterday in case anyone wants to see. Thanks.
Jesse |
#12 |
It was a dark and stormy
The wood sags immediately on being loaded.
Whether the Modulus of Elasticity of wood increases or decreases with time is another question. |
#13 | |
Jesse |
#14 |
Meaning, "It sagged an amount imperceptible to the eye". A sixteenth of an inch, perhaps?
If you dangled off the center of the span or even elsewhere you can use the deflection plus the formulas in the Engineering Toolbox to figure all the parameters of this beam. The formulas are not complicated but they are tedious. |
#15 | |
| Display Modes | |
| How long between tiling steps? | ptraz | Flooring | 4 | 03-12-2010 08:13 PM |
| How long does it take for Aura to cure? | slickracer | Painting | 8 | 01-03-2010 05:58 PM |
| Why long lasting bulbs go out of service quickly? | art2670 | Electrical | 8 | 10-27-2009 09:10 AM |
| The long, dark road of renovation. | Curb Feeler | Introductions | 1 | 02-03-2009 02:47 PM |
| Long range HVAC planning. | dalesd | HVAC | 2 | 02-23-2006 01:37 PM |
