How Long Should Water Stay In A Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-07-2013, 07:06 PM   #1
Rewards Points: 101
how long should water stay in a wall?
I've just opened up a few walls to remodel a bathroom. The area under the window that is right behind a toilet is wet. The drywall is moldy and black and the insulation was wet. it's been open for a few days now and the moisture is about gone. I bought the house in July and was told the toilet leaked so I turned the supply off and just now got to the demo. I can't see where there is a current leak and the supply has been off for several months. Is it reasonable for the moisture to remain for that long? Thanks, 1
1dumbquestion is offline   Reply With Quote
Old 10-07-2013, 07:37 PM   #2
Rewards Points: 13,220
How do you know it's not the window that leaking?
Post some pictures.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
jaydevries (10-07-2013), plummen (10-08-2013)
Old 10-07-2013, 07:51 PM   #3
Rewards Points: 101
Post some pictures.
It's possible but, the window is well tucked under an eve and the moisture is extended by several inches into the next wall at the corner heading to the insides of the house. I'll try to post pics but I'm not very good with that sort of thing.
The Following User Says Thank You to 1dumbquestion For This Useful Post:
Old 10-07-2013, 08:21 PM   #4
DIY staff
Rewards Points: 7,174
There is usually a large vent pipe in the wall behind the toilet---it may be possible that the vent pipe is leaking or the roof cap is no longer keeping out the water---
Pictures will help---that should have dried out long ago---picture of the inside and the outside wall and roof,if possible---Mike---
Old 10-08-2013, 05:48 AM   #5
Rewards Points: 4,526
you could also turn the supply back ON & flush the toilet a few times,,, that may eliminate or confirm 1 source of the leak,,, to complete the ' test ', sit upon the throne/can while flushing,,, sometimes body weight causes stress not found during flushes w/'no-load' ( so to speak )
The Following User Says Thank You to stadry For This Useful Post:
oh'mike (10-08-2013)
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Water in conduit MYSTERY feign3 Electrical 4 03-14-2010 09:17 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
