How Long To Make Beams - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-16-2012, 04:01 PM   #1
how long to make beams
I would like to build a pergola using 26' x 2" x 12" for the main structure that would bolt to 8" x 8" coming out of concrete or bolted to the concrete. I would like to park two autos under it without a support beam in the center.
I built a peaked roof using 18' beam spans several years ago in a high wind area and it is holding up very well.
selfmade is offline   Reply With Quote
Old 04-16-2012, 05:13 PM   #2
Framing Contractor
Your not spanning 26' with 2-2x12s.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following 2 Users Say Thank You to Joe Carola For This Useful Post:
user1007 (04-16-2012), woodworkbykirk (04-16-2012)
Old 04-16-2012, 05:17 PM   #3
Rewards Points: 268
It's gonna sag!
packer_rich is offline   Reply With Quote
Old 04-16-2012, 05:36 PM   #4
cortell's Avatar
Rewards Points: 504
I'd look into using glulams.
cortell is offline   Reply With Quote
Old 04-16-2012, 06:42 PM   #5
Rewards Points: 2,210
Hmmm, not sure it is a pergola so no real roof load but it's own weight.
mae-ling is offline   Reply With Quote
Old 04-16-2012, 06:59 PM   #6
cortell's Avatar
Rewards Points: 504
A pergola's beams definitely have a load--the weight of the rafters.
Old 04-16-2012, 08:47 PM   #7
How many 2x8s are you putting because if u put at least 3 or 4 it should be ok with the span
1 suggestion u can take into consideration is to put 1 on each end roughly 4' in and 1 in the middle that's how I did mine but the only diff. Is mine is 36' n I have a 6x6 every 7'
ninjahero is offline   Reply With Quote
Old 04-16-2012, 09:12 PM   #8
Framing Contractor
Read his first post again. 26' no post in the middle..
Joe Carola
Old 04-16-2012, 09:22 PM   #9
Framing Contractor
Rewards Points: 112
Building a pergola to park autos in?
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
Old 04-16-2012, 10:00 PM   #10
Well in that case you have a few options you can either beef it up with 3 or 4 2x12s or use LVL (laminated venire lumber) it's just as strong as 2 2x12 I think I can't remember but it is very strong and won't sag as easly
Old 04-16-2012, 10:50 PM   #11
Framing Contractor
In other words ....your guessing....very dangerous post you've made and should not be listened too.
Joe Carola
Old 04-16-2012, 11:01 PM   #12
No actually I'm not if u no war ur doing n do it properly u will have no safety issues
Old 04-17-2012, 08:20 AM   #13
I think your hardest issue will be getting a 26' 2x12. You can special order them but its not something your local big box lumber yard will carry. I suspect you will end up using LVL at the span you want. Go ask the guy at the lumber desk since you have to order it anyway. They have software that will tell exactly what you need and they will give you a quote for nothing.
bill01 is offline   Reply With Quote
Help us make a remodel decision for selling home pleas 3detailer Kitchen & Bath Remodeling 11 04-27-2010 12:36 PM
Attic joist cross beams & moving them Fox Building & Construction 11 04-02-2010 09:48 PM
lifting a house with wood beams jammer28 Building & Construction 9 03-27-2010 03:21 PM
10x16 eave vent intake - buy or make Rald Roofing/Siding 2 01-29-2010 06:46 PM
Long range HVAC planning. dalesd HVAC 2 02-23-2006 01:37 PM
