How Long Does New Brick Mortar Have To Dry Before Cutting For Roof Counterflashing? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 05:56 AM   #1
How long does new brick mortar have to dry before cutting for roof counterflashing?
I am replacing some spalled bricks and tuck pointing all the brick joints to just below the roofline. When I ground out the old mortar with a 1/4" segmented diamond blade it took some effort and time. The mortar was hard as a rock.
When I replaced bricks I overfilled the joints but didn't strike/finish them. I figured my last step would be to grind them out the same depth and tuck point all the bricks and lock everything together.
My concern is that the diamond blade eats through the new mortar like butter. Should it be so soft? I'm talking about joints that were 2-7 days old. Should I wait longer before cutting a slot for the counter flashing? Being mid November I'm sure isn't helping.
mjzraz is offline   Reply With Quote
Old 11-13-2011, 07:59 AM   #2
Im in Maryland just south of Baltimore. The next couple of days are forecast to be highs in the 60's and lows in the low 50's getting colder by weeks end but generally in the 50's and 40's with I think Friday night being the lowest at 35, then lows in the 40's after that.
Old 11-13-2011, 08:32 AM   #3
Rewards Points: 5,336
Why don't you install the flashing before you point the bricks?
Ron
B. Franklin 1759
Old 11-13-2011, 09:00 AM   #4
I guess I never thought of that. The only reason I have to not do that is I am replacing the roof sheathing and shingles and I was waiting for the chimney work to be done first. At least that was my plan. The more I read about repointing in cold weather the more I am thinking of tar ping off the chimney for the winter as much as that sucks to not finish it, I would rather have a good quality result.
I suppose I could point all the bricks except where I am putting the flashing and point them when the flashing goes in.
Cutting a large hole in brick veneer wiz561 Building & Construction 4 09-09-2011 10:44 AM
Cutting Cement Pavers and Brick Thadius856 Landscaping & Lawn Care 16 09-02-2011 10:59 AM
how to make white mortar for brick wall nhertel Building & Construction 2 05-26-2009 08:22 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
Mortar removal from salvaged brick. Rem8 Building & Construction 8 07-20-2008 07:05 AM
