How Long After Skim Coating... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2009, 06:35 PM   #1
HandyWoman
How long after skim coating...
should I wait to prime and paint.
Or how long can I wait, should I give it a good day or so to cure?
Any help would be appreciated!
2600truman is offline   Reply With Quote
Old 07-17-2009, 06:39 PM   #2
i would wait a day. But if it is a true skim coat it will dry very quick. you could probably get away with it after a few hours.
beerdog is offline   Reply With Quote
Old 07-19-2009, 02:15 AM   #3
HandyWoman
thanks, that helped.
Old 07-20-2009, 06:22 AM   #4
I guess it will depend on how much you are leaving on. If you are just smooothing out a painted surface or bare drywall then it will dry quick. if it is a rougher texture or larger voids then it may take a day.
Old 07-20-2009, 07:40 AM   #5
General Contractor
Also depends what kind of joint compound you are using. Quick drying compounds may dry to the touch in as little as 20 minutes. The chemical reaction behind the dried mud may still be occurring beyond the listed curing time. In most cases I wait 24 hours after the skim coat to sand. After the clean up I will prime the walls with flat white paint (actually works better to prevent flashing than primer). Then you can check the walls for areas that need to be pointed up. After point up prime the areas you pointed up and you are ready for color application.
ARI001 is offline   Reply With Quote
Old 07-20-2009, 08:05 AM   #6
what is flashing?
Old 07-20-2009, 08:20 AM   #7
General Contractor
Originally Posted by beerdog View Post
what is flashing?
Flashing is when the underlying surface shows through the painted surface in certain lighting situations. Basically when you look at the wall after it is painted and you are able to see the joint lines and nail spots through the paint.
Old 07-21-2009, 12:10 AM   #8
HandyWoman
why does white paint work better than primer?
a lot of people have suggest I use Guardz, which is supposed to seal fresh drywall, or compound work...
Old 07-21-2009, 08:37 AM   #9
General Contractor
Primers do not contain enough resin to even out the porosity of the different surfaces (compound/sheetrock). Sealers even out the the porosity but don't correct variations in textures. Latex flat finish provides good coverage, minimizes flashing, corrects texture variations, and evens out variations.
Old 07-21-2009, 08:58 AM   #10
Interesting. I do not doubt you, but why do the paint stores never recommend this?
Old 07-21-2009, 09:20 AM   #11
General Contractor
Most people working in the paint stores regurgitate what ever is told to them by whoever trained them. I have run into a few guys over the years that knew their stuff but most don't. It also fattens their bottom line more to sell you primer and paint than just the paint. Most will tell you one coat of primer and two coats of paint. The same job may be able to be completed with two coats of paint (some colors excluded). Remember you can have the base coat tinted to match and then if you want satin finish only the top coat needs to have satin sheen.
what trade do I call? skim coating Dusty General DIY Discussions 4 04-07-2009 10:53 AM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
Roller skim coating - how to beerdog Painting 5 01-10-2009 11:00 AM
Skim coating wall help pesphoto Building & Construction 3 05-03-2007 06:43 PM
Reflective Coating on Flat Roof MelindaA Roofing/Siding 3 01-05-2006 05:08 AM
