How To Lay My Decking Boards - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-13-2010, 12:29 PM   #1
how to lay my decking boards
im trying to have no seems in my deck and the only way i can do that is to run my decking boards the same way ive run my joist can i do that? im putting in enough bridging inbetween each joist so theres no sagging my deck is 28 wide an 14 long
usc529 is offline   Reply With Quote
Old 02-13-2010, 01:29 PM   #2
jlhaslip's Avatar
Rewards Points: 390
what material are you using?
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 02-13-2010, 02:03 PM   #3
Rewards Points: 5,336
If you're running the deck boards the 14" direction, you can get away with no seams. How much blocking you would need, as posted by jlhaslip, would depend on the decking material.
If you were using 2x4's or 6's, you could get away with blocking at 24". Using 5/4" material would require 16" spacing.
If you're using exposed fasteners, you will need to line up the blocking if you want the screws in a straight line.
Ron
Old 02-13-2010, 05:19 PM   #4
im useing 2x10 pressure treated wood i want no seems but i keep reading everywhere that u must run your decking the opposite way your joist are so im kinda confused i want the deck to be sturdy and i know if i run the board opposite of the joist it will be sturdy not sure what to do
Old 02-13-2010, 06:08 PM   #5
Framing Contractor
You can run the decking perpendicular to the joists using 14' decking by put a style strip in the center running with the joists and then butting the 14' decking into that strip.
Joe Carola
Joe Carola is offline   Reply With Quote
Trex decking LL1 General DIY Discussions 56 09-30-2011 10:55 PM
Trex Decking over Treated Decking retired2pa General DIY Discussions 6 12-15-2009 07:16 PM
Composite Deck Boards dgoodwin3364 Carpentry 10 06-05-2009 12:09 PM
Cedar decking Bucky Badger Carpentry 8 04-24-2009 07:44 AM
hardwood flooring boards matjone Flooring 4 02-01-2008 06:35 PM
