How To Know If Basement Walls Are Exterior Insulated? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 01:51 PM   #1
HomeOwner
Rewards Points: 81
Send a message via Yahoo to Firehawk734
How to know if basement walls are exterior insulated?
Is there a way to tell?
Did it become code at some point recently so that builders automatically do this?
Is there some way I can check, or where do I have to go to find out?
My house was built in late 2003 and I live in Michigan. I have city water, and have a sump pump. Not sure if this matters.
Thanks in advance!
Firehawk734 is offline   Reply With Quote
Old 12-18-2011, 01:56 PM   #2
concretemasonry's Avatar
Rewards Points: 2,570
Do you have a shovel? Construction practices and code enforcement can vary from area to area.
Dick
concretemasonry is offline   Reply With Quote
Old 12-18-2011, 02:04 PM   #3
HomeOwner
Rewards Points: 81
I do have a shovel, yes I can dig, but what will it look like? How far down do I need to dig? Since I'm not a pro, nor ever used exterior insulation that goes into the ground, I don't know what I'm looking for.
Smart azz...do I have a shovel....
Old 12-18-2011, 08:20 PM   #4
Rewards Points: 150
Dig, Dig, Dig,
The only sure way if a poured concrete foundation, is to dig down alongside the foundation. If it is insulated you will find an insulating material, typically a foam board in NY, up against the foundation. It will start just below grade or at the top of the foundation and be protected in some manner for the portion of foundation above grade.
TheCamper is offline   Reply With Quote
The Following User Says Thank You to TheCamper For This Useful Post:
concretemasonry (12-18-2011)
Old 12-18-2011, 11:43 PM   #5
HomeOwner
Rewards Points: 81
Thanks guys I dug down about 1 foot or so and didn't see anything so I'm assuming there isn't any. The house wasn't 'custom' so I'm thinking builders don't add that unless requested.
Old 12-19-2011, 12:01 AM   #6
Rewards Points: 558
you should be looking for something like this:
epson is offline   Reply With Quote
Old 12-19-2011, 11:25 PM   #7
Facilities Maintenance
Buy foam insulation, and install inside your basement. If you're not sure, do it yourself. =)
If you're insulated from the outside, oh well. If not, you'll have insulation for your basement.
You can than claim that when you got o sell the house, you've got an insulated basement, or a double insulated basement. Either way, it wouldn't hurt.
BigGuy01 is offline   Reply With Quote
How to Prep. Basement Walls for Painting vcheez Building & Construction 37 08-12-2011 10:32 AM
framing basement walls with furred ceiling BlueBSH Building & Construction 10 08-05-2011 01:44 PM
vapor barrier plus inside the basement when walls are sealed with a penetrable sealer concrete walls myhouse2010 Building & Construction 1 10-18-2010 12:35 AM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 07:27 PM
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 04:42 PM
