How To Keep Lower Deck Dry - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2010, 12:51 PM   #1
How to keep lower deck dry
I've got a two story porch on an apartment building I own. I'm replacing the decking on the upper as the previous owner put plywood over the flooring to keep the lower deck dry. This was compounded by using plywood instead of balusters around the 3 sides. This was effectively a bathtub which rotted out all the plywood and the decking underneath. So far, the joists are ok.
I know there are some expensive solutions out there to keep the lower deck (porch) dry. Here is my less expensive thought:
- Use 2x6 as decking (they cost the same as decking here)
- Don't space them at all when installing (as I understand, the 2x6 won't shrink much)
- Make sure they pitch enough for the water to run off/down the upper deck via the channels between the 2x6s.
- Of couse I'm opening up the sides and just using balusters, installed 3" up from the decking.
I understand, the decking won't have quite the life expectancy of a niced spaced decking, but being a rental, I'll probably have to replace sooner than later due to stains and other damage anyway.
Thoughts?
Seth22 is offline   Reply With Quote
Old 06-28-2010, 08:13 PM   #2
I have a similar situation and would like to keep the rain off the lower deck!
I have seen corrigated plastic panels at the building supply center and I'm thinking of strapping the underside, of the upper deck joists and fastening the panels to the strapping.
The strapping would have to be installed in such a manner, so that the panels would have 'fall' to drain away the water.
Anybody see any problem with this idea?
Old 06-29-2010, 09:02 AM   #3
I've thought about the plastic panels as well. I think even that pricing was higher than I was looking for. If it was my house, I think might try those, this is for an apt building.
Deck Staining Nightmare steven994 Painting 7 06-14-2017 04:56 AM
Deck Addition - Floating to Attached Foundation eemichael83 Project Showcase 15 08-22-2010 09:40 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
