How To Jack Up On Grade Floor? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 03:01 PM   #1
How to jack up on grade floor?
Hi my kitchen floor is out of level by approx 2inches at one end
and maybe 1 inch at the other and forms a kind of ridge in the middle.
This floor is on grade with approximately 4 inches between the bottom of the
joists and the ground. The joists consists of tree trunks sawed in 1/2 and 2x6s. I have been told
that the only way to flatten out the floor is to jack it up using bottle jacks.
Any suggestions on how to do this, most of the methods on line seem to
be for floors with normal basement heights beneath. Could I use bottle jacks
to move the joists up and then shim the space between the joist and the sill
with something? Hardwood shim or something?
porchhen9 is offline   Reply With Quote
Old 12-19-2011, 04:10 PM   #2
Just a DIY guy
hopefully one of the "real" contractors will pipe in here, but I'll give my two cents.
If your kitchen is the only room you need to fix, then I'd just sister in new joists along the old ones, using the new joists to achieve a level floor. Of course, you'd need to remove the floor and subfloor to access the joists, and probably have to gut the room so the wallboard or plaster/lath is not in your way.
Given that you have a hump in the middle of the floor, I doubt jacking is going to level it out, even if you could figure out how to do it.
You may also need to look at how the floor is supported, to eliminate future sagging.
M3 Pete is offline   Reply With Quote
Old 12-19-2011, 04:57 PM   #3
My friend had a similar problem and he ran tapered stringers, perpendicular to the floor joists and then applied 5/8 t/g plywood over top of the stringers.
Old 12-19-2011, 08:24 PM   #4
AGWhitehouse's Avatar
M3 Pete has the right idea...you'll need to do a full gut to remedy that problem correctly.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 09:32 PM
engineer wood floor @ uneven Slab on grade gtimk4 Flooring 0 03-21-2010 06:29 PM
Floor Drain retrofit for Slab on Grade Douger_F Plumbing 3 04-02-2009 11:07 AM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
