How To Insulate Rim Joist With Drop Cieling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 03:54 PM   #1
Rewards Points: 640
how to insulate rim joist with drop cieling
What is the proper way to insulate a rim joist in the basement when you have a drop cieling? Right now I have walls drywalled up to the joists for the 1st floor... then the rim joists are not insulated... the cieling is a drop cieling and I dont want to drywall it due to the amount of plumbing in there...
BlueBSH is offline   Reply With Quote
Old 01-03-2010, 04:02 PM   #2
Rigid foam insulation. You can either cut pieces of solid foam and then spray foam them with a can to seal it good and hold them in place OR buy the spray foam kits that they sell.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 01-03-2010, 04:20 PM   #3
Rewards Points: 640
doesnt that still need to be covered up as a 15minute fire barrier? or does the drop cieling count as that?
Old 01-03-2010, 04:36 PM   #4
http://doverprojects.blogspot.com/20...im-joists.html
FirefighterGW is offline   Reply With Quote
Old 01-03-2010, 07:45 PM   #5
Rewards Points: 640
not really sure if that site answered my question or not, they use a type of insulation that is non-flamable, but this isn't available in my area... all I have is XPS it seems like
Large metal "tabs" in openings cut in bi-level rim joist... What are they? Insulate? nutlog Building & Construction 9 11-09-2009 03:19 PM
Sagging sheetrock in garage cieling, need to seal it to insulate. 240sx4u Building & Construction 6 01-01-2009 05:24 PM
Insulate joist bays along with radiant heat, how ? iMisspell Building & Construction 2 12-08-2008 12:17 PM
Metal framing for basement Drop Cieling? joliet_man@yahoo.com Carpentry 3 10-22-2008 01:16 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
