Old 07-12-2007, 10:02 PM   #1
how to insulate my attic (pics inside)
The length between the joists are 24". What type of batts(and what dimensions) should I buy? Are there any tricks to make them fit snugly between the joists?
Thank you in advance!
handbanana is offline   Reply With Quote
Old 07-13-2007, 06:04 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
H.B.,
First off, this question depends on the part of the country where you live. If you are in a colder climate, that framing would not suffice to allow the proper thickness for an appropriate and code required R-Value insulation. If you live in a warmer climate, then that is obviously different.
Second, when you install insulation in those areas, you are supposed to have rafter vent in each rafter bay to allow for warm moist air flow up and out through the ridge vent.
Link: http://www.owenscorning.com/around/v...mate_attic.asp
You could look into 24" width insulation. The issue with this is that it is difficult to find 24" wide insulation that would fit flush into such a shallow cavity (2'x 8' = 7-1/4" actual cavity measurement). 24" R19 might work, if is compliant for you locality.
You would need to install somekind of vapor barrier facing the finished attic, if the insulation did not have one.
You could also attach nylon insulation straps to the underside of the rafters in order to hold the insulation batts up during and after the installation process.
Another option: http://www.foam-tech.com/products/Icynene.htm
Last, I am not familiar with attic insulation practices for warmer environments. Example: Florida. That could be a different "animal" altogether that another member may post about.
- Build Well -
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 17 09-06-2008 01:59 PM
Proper Attic Insulation reikiray Roofing 5 08-04-2007 11:59 AM
How would you insulate this - Pics - J187 Building & Construction 5 06-12-2007 11:17 AM
Deck - 45º spindles - advice wanted (pics inside) Kevin K Building & Construction 21 06-06-2007 11:28 AM
This is bad, right? (pics inside) dalesd Roofing 8 02-16-2006 09:33 PM
