-   -   how to insulate my attic (pics inside) (http://www.diychatroom.com/f19/how-insulate-my-attic-pics-inside-9852/)
handbanana 07-12-2007 09:02 PM
The length between the joists are 24". What type of batts(and what dimensions) should I buy? Are there any tricks to make them fit snugly between the joists?
Thank you in advance!
http://img242.imageshack.us/img242/8496/img3.jpg
http://img242.imageshack.us/img242/351/img1.jpg
http://img242.imageshack.us/img242/7672/img5.jpg
http://img242.imageshack.us/img242/166/img2.jpg
AtlanticWBConst. 07-13-2007 05:04 AM
H.B.,
First off, this question depends on the part of the country where you live. If you are in a colder climate, that framing would not suffice to allow the proper thickness for an appropriate and code required R-Value insulation. If you live in a warmer climate, then that is obviously different.
Second, when you install insulation in those areas, you are supposed to have rafter vent in each rafter bay to allow for warm moist air flow up and out through the ridge vent.
Link: http://www.owenscorning.com/around/v...mate_attic.asp
You could look into 24" width insulation. The issue with this is that it is difficult to find 24" wide insulation that would fit flush into such a shallow cavity (2'x 8' = 7-1/4" actual cavity measurement). 24" R19 might work, if is compliant for you locality.
You would need to install somekind of vapor barrier facing the finished attic, if the insulation did not have one.
You could also attach nylon insulation straps to the underside of the rafters in order to hold the insulation batts up during and after the installation process.
Another option: http://www.foam-tech.com/products/Icynene.htm
Last, I am not familiar with attic insulation practices for warmer environments. Example: Florida. That could be a different "animal" altogether that another member may post about.
