Old 11-16-2012, 10:42 AM   #1
How to Insulate Flush-Mount Basement Windows
How do I add insulation to these flush-mount basement windows?
Should I build a wooden frame around the window so that I can shove in rigid insulation?
Any ideas would be appreciated!
Annie
How to Insulate Flush-Mount Basement Windows-pict0015.jpg   How to Insulate Flush-Mount Basement Windows-pict0016.jpg
Ann Katz is offline   Reply With Quote
Old 11-17-2012, 09:39 AM   #2
if you don't want it to be a window anymore = remove the sash. put plywood over the hole (seal with caulk). add insulation. then another piece of plywood.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 11-17-2012, 10:21 AM   #3
Even if you did that, those windows do not look too energy efficient. I would look into a window replacement. Those sized windows can be had at the big box stores a lot cheaper than a full sized window.
B
Beepster is offline   Reply With Quote
Old 11-17-2012, 10:27 AM   #4
And that dryer vent needed to be run through a hole in the brick wall not through the window.
Sure would make it easyer to do something with the window.
Old 11-17-2012, 10:27 AM   #5
Those windows need to be insulated on the outside. If you do interior insulation you'll be insulating the room heat from the glass which will become colder and the end result will be condensation running down the walls.
Fairview is offline   Reply With Quote
Covering Basement Windows critter7 Windows and Doors 13 06-16-2012 11:51 AM
Insulate unfinished basement walls? DennyF Insulation 3 02-28-2012 01:36 PM
Porcelain Install Job on Basement Slab, How to make Floor Drain Flush... Firehawk734 Flooring 13 11-17-2011 10:30 PM
Framing/Finishing around basement windows archiero Remodeling 7 05-08-2009 11:04 PM
Basement windows in masonry walls dave11 Building & Construction 1 03-20-2009 09:28 PM
