How To Insulate Floors Above An Unheated Basement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 08:45 PM   #1
how to insulate floors above an unheated basement?
My contractor installed fiberglass in the ceiling of basement with the paper side faced up slightly touching the sub floor. now the top side is exposed and my tenant is now moving out because she is complaining her kids have a rash from the insulation . The insulation seems to be flaking down from the ceiling. Is there something less expensive than sheetrock to cover this exposed facing?
mfrenkel is offline   Reply With Quote
Old 07-23-2010, 07:45 AM   #2
Foam insulation can be an alternative, but you would have to put something underneath to hold it up (drywall, plywood boards).
But depends on your budget and how much work you want to put into it
Jas.Dou is offline   Reply With Quote
Old 07-23-2010, 08:26 AM   #3
Rewards Points: 502
about the only thing cheaper than sheetrock would be house wrap.
forresth is offline   Reply With Quote
Old 07-23-2010, 01:28 PM   #4
Rewards Points: 590
Sheetrock is pretty cheap. Am I understanding this correctly, that the kids are spending enough time in an unfinished basement to get a rash from a small amount of fiberglass insulation?
operagost is offline   Reply With Quote
Old 07-23-2010, 02:59 PM   #5
Totally screwed together
But could you buy it in a small enough roll for you to be able to realize that price difference?
xxPaulCPxx is offline   Reply With Quote
Over insulate basement? braverichard Building & Construction 26 06-22-2010 08:26 PM
Insulate basement walls, 1/2 concrete / 1/2 wood frame rovers1973 Building & Construction 1 04-25-2010 05:50 PM
Painting concrete basement floors shimga Flooring 3 04-24-2010 02:46 PM
Can i insulate first floor exterior wall the same way as basement? the punisher Building & Construction 2 04-23-2009 12:03 PM
Insulate a basement walkout door? Shamus Building & Construction 3 09-25-2008 11:10 AM
