How To Insulate Behind Gas Fireplace - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-02-2006, 03:50 PM   #1
how to insulate behind gas fireplace
im not sure but i think it may be call a dog house? the area the gas fireplace slides into, in the wall. anyway, i assume there is special insulation that has to go in there first. am i correct? if so what an does chicken wire have to be used to fasten it to the wall?
THEBIGPUNN is offline   Reply With Quote
Old 09-25-2006, 08:02 PM   #2
remodeling pro
It doesn't have to be an special insulation. Just be sure there is none of the paper barrier left on for this application. Chicken wire certainly will keep the insulation from falling but it is probably overkill. I usually run framing scraps through a table saw to make lath strips of any convenient size and tack them up with a finish nailer about 14 to 16 inches apart.
troubleseeker is offline   Reply With Quote
Old 09-26-2006, 04:20 PM   #3
General Contractor
I would make sure the insulation doesn't touch the fire box. If the manufacturer has clearance requirements for that particular fire box go by what they say.
fqp25 is offline   Reply With Quote
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 08:17 AM
Gas Fireplace ChrisSensabaugh HVAC 3 07-31-2007 06:08 PM
huge fireplace issues krynstar Painting 10 03-10-2007 06:41 PM
Fireplace leaking mmcginn2 Roofing/Siding 4 04-23-2006 10:12 AM
Water leaking over fireplace mmcginn2 General DIY Discussions 1 04-20-2006 11:42 PM
