How To Install A Window Well Cover - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-08-2010, 02:48 AM   #1
how can I install a window well COVER onto a window well made of WOOD?
how can I install a window well cover over a well made of WOOD? I would like to install it so in an ER one can open the cover from the inside.
Sharon Vaughan is offline   Reply With Quote
Old 09-08-2010, 06:51 AM   #2
I have made a number of "custom" window well covers from a simple PT wood frame and a piece of Lexan. It is open on the ends for ventilation if needed, and simply slopes for water run off. It can be easily removed if needed. I used Lexan because it is litterally bullet proof and falling limbs, hail, etc., can't break it.
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 08:15 AM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Window install question reguarding tyvek marlinpuppy Building & Construction 2 02-12-2009 12:56 PM
Correct way to install aluminum window casing? DavesHammer Remodeling 7 01-16-2008 01:39 PM
Cut and install new window mustanger Building & Construction 4 12-01-2007 12:18 PM
