How To Install A Metal Fence Post DEEP Into The Ground? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2011, 11:53 PM   #1
How to install a metal fence post DEEP into the ground?
Hi guys, i'm trying to do a project that will involve me using steel chain and hooking it onto a metal fence post. The metal fence post i've decided to use is something like this (click), and should be around 6 ft - 8 ft.
The question i wanna ask is: how do i install the metal fence post so only about 2" of it is exposed on the ground? I've thought about using a hammer, but since it is going to go in so deep, and the surface is dirt, it might get a little difficult.
I've thought about using a metal fence post driver, but honestly, i don't know where to rent one, and even if i did, i think it's be pretty expensive just to install a metal fence post...
So i was wondering if you guys could give me some tips on how you would bang the fence post into the earth while on a budget...
Thanks all, cheers!
update
I went to home depot to buy a flat steel stake in the pix below. It seems a little hard to sink this into the dirt with ordinary claw hammer.. Its 3 ft, 1.5 x 3/8. Are sledgehammers better?
boba7523 is offline   Reply With Quote
Old 09-15-2011, 01:17 AM   #2
Sounds like you need someone with a small auger implement for their yard tractor to do it.
That said - pending what your project details are - once you get past a certain depth with that style of post you're not going to have any added strength/resistance than you would've with a shorter length. You'd probably be just as good (if not better) off using a 2-3' depth with some proper concrete (or using a corkscrew style rod, etc).
dayid is offline   Reply With Quote
Old 09-15-2011, 02:38 AM   #3
Here is a Youtube video of what my project is. It's basically a punching bag stand made from 2 beams, and a chain anchored onto a metal fence post that's banged deep into the earth. It has nothing to do with fencing but rather just using a metal fence post as an anchoring point for the chain The punching bag i'm going to hang will range from 70-150 lbs at most, so that's the maximum weight the chain and metal fence post has to be able to hold.
Is concrete absolutely necessary for this? i was thinking of just using a hammer or some sort of tool to get the majority of the metal fence post into the ground (so as to not cause hazard to children or bypassers who might come on my property).
Old 09-15-2011, 06:50 AM   #4
Rewards Points: 5,336
Post hole digger.
Ron
B. Franklin 1759
Old 09-15-2011, 08:42 AM   #5
Rewards Points: 6,652
What are you trying to anchor, Bigfoot? All you need to do, is put in a pile about 3 feet deep, and anchor a eye-bolt. It is very doubtful that you are going to move that out of the ground, no matter how hard you try. Some people have used either steel tubing anchored in the ground, or have used pressure treated wood, with that anchored to keep from moving.
Old 09-15-2011, 10:29 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Talk about OVERKILL! You will never successfully drive six feet of a galvanized fence post into the ground without destroying it after the first ten inches.
Go back to HD and buy an eighteen inch long or twenty-four inch long steel-concrete-form-stake and drive it at a slight angle like a horshoes pin and call it good.
Old 09-15-2011, 12:08 PM   #7
Or even just using an anchor that it used for tie-downs on a trailer or shed, would even work better.
The Following User Says Thank You to gregzoll For This Useful Post:
Bud Cline (09-15-2011)
Old 09-15-2011, 12:57 PM   #8
Experienced
Jackofall1's Avatar
Drive in a 2' long stake, steel or wood, 90* to the line which will hold up the bag.
Mark
Old 09-15-2011, 01:52 PM   #9
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
if you insist on sinking a pipe a water drill would probably be the easiet way to do it , provided you don't hit any big rocks below the surface
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-16-2011, 01:53 AM   #10
Wow THANK YOU EVERYONE for giving me helpful suggestions/aid! I truly wasn't expecting this much of a reply, at least in such a short time frame! You guys ROCK. If i didn't ask for help here, i'd look like a total idiot trying to sink a galvanized fence post into the ground.
i like the idea of using a steel concrete stake. i've never had experience with trailer anchors but also like that idea as well since it's heavy duty. A few questions i have regarding using the steel concrete stake:
1.) Can i drive it at a 45* angle away from the direction of the heavy bag?
2.) do you guys think the steel concrete stake will hold its place and not get pulled up by the force of the heavy bag? 100 lbs + force from punching/kicking/etc
3.) As for anchoring it, i can basically just use an eye bolt into one of the holes on the stake, and if the hole is too small, i just drill it to the right size right?
Old 09-16-2011, 01:56 AM   #11
Mark
A bit confused by what you're referring to by the "line."
Can i drive it 45* in the opposite direction of the bag?
SO basically do this:
(BAG)--------- /
Instead of this:
(BAG)--------- l
Old 09-16-2011, 10:01 PM   #12
bump for help, if bumping is not allowed, please let me know
Old 09-17-2011, 06:38 AM   #13
In the video he is using a steel "T-POST" not a round post
much easier to drive with a sledge hammer or post driver
Tnut
tnut is offline   Reply With Quote
Old 09-20-2011, 05:18 PM   #14
Old 09-20-2011, 06:34 PM   #15
jschaben
Rewards Points: 502
http://www.pet-dog-cat-supply-store....-flypage-36611
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Fence panel / post width: 10' VS 8' CZSteve Building & Construction 4 05-27-2011 06:37 AM
wood fence post farrington135 Building & Construction 11 05-17-2011 02:32 PM
How to replace a loose fence post preciouschristy Building & Construction 2 05-14-2011 05:06 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
Fence Post Problem cdubim Building & Construction 3 03-12-2007 01:09 PM
