How To Install Flashing On Flush Windows. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-22-2010, 09:53 AM   #1
How to install flashing on flush windows.
I have a handyman installing my new Reliabilt windows and everything looks good except for the flashing. The windows are set in flush with the side of the house and then he has taken a piece of flash about 4 or 5" and just went around the window and overlaps the side flashing with the bottom flashing. The problem, from what I can see, is that there is no bend to sturdy the piece of flash. The edge of the flash is wavy looking and not flush with the side of the house. Any solutions here?
Last edited by Franksr; 10-22-2010 at 09:55 AM. Reason: placed picture below text.
Franksr is offline   Reply With Quote
Old 10-22-2010, 10:27 AM   #2
kwikfishron's Avatar
Rewards Points: 586
I’m not seeing it in your picture.
Can you post a straight on shot?
kwikfishron is offline   Reply With Quote
Old 10-22-2010, 11:03 AM   #3
Here is a Close up
I think you might be able to tell what I'm talking about here. If not I will send you the picture of the whole window with flashing.
Old 10-22-2010, 01:25 PM   #4
Rewards Points: 586
What you’re calling flashing is where your new wood trim should be with the trim caulked to the window and the siding.
Old 10-22-2010, 01:36 PM   #5
Wow that looks like crap. What good is that flashing going to do? Nothing
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 10-22-2010, 01:54 PM   #6
So your saying it should have trim around the window?
These are replacement windows and so I need to add a wood trim all the way around the windows, then flash over that or forget the flash?
Something like 1 x 3s or 1 x 4s?
And thanks to wnabcptrNH as I already knew it looked like crap but appreciate your comment.
Old 10-22-2010, 06:05 PM   #7
Why even install the flashing is my question?
Old 10-22-2010, 06:19 PM   #8
Registered User
Rewards Points: 5,514
That appears to be T1-11 structural siding with 8"o.c. grooves. If so, the window should install with flanges flush with the back of it. Cut the hole bigger, install sill flashing, head flashing, install window, sticky tape, trim. He is taking the easy way but it will leak relying on caulking under the jamb flashing.
Gary
Old 10-22-2010, 06:22 PM   #9
Rewards Points: 586
No flanges G.
Old 10-22-2010, 09:33 PM   #10
Registered User
Thanks! Missed that or didn't compute.... From the picture it looked like the 1/8" bump just under the bottom of the last sill flash is a window flange. Lotsa caulking there....
I'm old-- and I'm using that (on this one)....
Gary
Old 10-23-2010, 07:39 PM   #11
Tom Struble's Avatar
Rewards Points: 2,002
hey ''im old'' is mine
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Gary in WA (10-23-2010)
Need correct steps for install OSB, Tyvek, Windows tljbcrew Building & Construction 0 08-09-2010 10:35 AM
install exterior windows paul Davidson Building & Construction 0 08-07-2010 03:28 AM
Typical Cost to Install Anderson 400 Windows jombres General DIY Discussions 1 10-16-2009 09:57 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Cutting brick to install windows (lentals?) buckwillis Building & Construction 6 08-21-2006 08:13 PM
