Old 07-16-2011, 02:34 PM   #1
How to install drain behind foundation wall?
Hi all,
Before I finish off the basement I am going to have to take care of a moisture problem along one side of the concrete block foundation wall. Until recently, I have only noticed moisture coming through in two corners, however after a period of lots of rain, I noticed that there is also moisture wicking through the blocks on the back wall as well (between the moist corners). I will say that we have a pretty good slope to our property and the moist wall is on the uphill side (which makes sense). The floor on this side of the basement is about 10 ft below grade, and the opposite side is at grade (kind of gives an idea of the slope of the property). So before I dig down 10 ft along the house to install a drain, I figured I would try to get some advice/suggestions. My plan is to excavate along this side of the house (down 10 ft) to the level of the basement floor and install some kind of drain. Any ideas how much it would cost to pay someone to excavate down to 10 ft along the entire side of house (40 ft long)? Any other alternatives?
Bahuffma is offline   Reply With Quote
Old 07-16-2011, 02:35 PM   #2
Another thing, if I do have to dig out all the way down along the foundation wall, what else should I do to help waterproof the outside wall?
what to do with the french drain behind a retaining wall MLMIB Building & Construction 4 04-08-2011 08:52 AM
Retaining Wall Level Foundation sippinjoes Landscaping & Lawn Care 5 04-03-2011 10:01 PM
French drain tile exterior wall lsaucy Building & Construction 4 05-30-2010 05:22 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 01:07 PM
