How To Install Cedar Shingle Siding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-07-2012, 01:26 PM   #1
Rewards Points: 358
how to install cedar shingle siding?
I have been researching this online and I am getting conflicting reports on how to install cedar shingle siding. What are you guys doing. I am in the process of re-siding my hosuse and we decided to try out cedar shingle gable ends. Hoping its not to difficult for a first timer. I have two gable ends and the area of each is about 50 square feet, so my first quetion is now much shingles do I get? Is it just like roofing materials? 3 bundles to 1 square and 1 square is 100 sq ft?
I understand the layouts and such and how to get it started but I cant find a good way to nail it.. Some places say nail each shingle 2 times at the top and 2 times at the bottom, other places say nail several times in in the area where it will be hidden by the next coarse of shingles so you don't see any fasterners. Some places say use staples, others say use naisl.
I have 3 options, hand nail using whatever nails are best, I also own an 18g brad nailer/stapler combo nailer, and a roofing nailer.
Can you guys set me straight on how this stuff works?? Thanks in advance!
cbzdel is offline   Reply With Quote
Old 05-07-2012, 02:22 PM   #2
kwikfishron's Avatar
Rewards Points: 586
I use 7/16 X 1 ” Stainless Steel staples on shingles (not shakes) and small (5d) SS ring shank siding nails when the fasteners have to be exposed (under windows, last coarse, etc).
Staples hold better than nails for shingles because the crown of the staple bridges over the grain of the wood to hold it down.
Generally just 2 staples per shingle no more than an inch above the line where the next course will cover.
There are 4 bundles to a square based on a 5” exposure not counting waste.
kwikfishron is online now   Reply With Quote
Old 05-07-2012, 08:50 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,212
i pretty much do the same as kwik. the smaller the exposure per coure the more shingles you'll need. installing a rain screen behind the shingles first will greatly lengten the life of the shingles, be it via "cedar breather" or privacy lattice
woodworkbykirk is online now   Reply With Quote
Old 05-07-2012, 10:15 PM   #4
Registered User
Rewards Points: 5,514
http://publicecodes.citation.com/ico...003_par008.htm
Hit "next section" on those pages to read more.
Gary
P.S. You need 16 gauge.....
The Following User Says Thank You to Gary in WA For This Useful Post:
kwikfishron (05-08-2012)
Old 05-07-2012, 10:19 PM   #5
Haverhill Trade 1965
As in Audel's Carpenters & Builders Guide (1923), only two nails per shingle no matter what width, 1/2" to 3/4" in from the edge, 1" above the bottom of the next course. (Staples each penetrate twice 2 X 2 = 4 nails and movement causes 4 splits over time). every shingle in the next row should cover both joint and nail of the row below by at least 1/2". Also look at the grain, if there are fuzzy ends pointing up, the ends of the grain allows water to soak into the shingle. Turn the shingle around so water runs out over the grain. Cedar shakes expand & contract with humidity so space them 1/8" or more depending on size, a little more for larger shakes. I have seen a few guys cut the bottom edge 2" in, at a 45 degree angle where the shingle meets the rake so there is no "short grain" to dry and break off
Duckweather is offline   Reply With Quote
Old 05-08-2012, 03:24 PM   #6
Rewards Points: 586
The rules have changed since 1923.
The Following User Says Thank You to kwikfishron For This Useful Post:
woodworkbykirk (05-08-2012)
Old 05-08-2012, 05:47 PM   #7
2 nails will work for smaller shingles but for wider ones you'll need more when they start getting wider than 6" so to keep them lying flat
Old 05-08-2012, 06:54 PM   #8
Rewards Points: 586
I can not stress the point enough that
staples hold sidewall shingles better than nails.
I’ve tore off more than my share of Cedar Shingle Siding and before the new job begins, you prey there nailed.
Nailed shingles just “pop” off the wall. Tear them off, beat in the nails and done.
Stapled shingles…not so fun. You’re literally breaking the shingles off the wall. You end up with all those staples left with a chunk of Cedar Meat stuck underneath. You have to blast every staple with a cats paw to clean it up.
25 years ago stapled sheathing was ok, not anymore. Stapled Roofing was all the craze for awhile too, you don’t see that anymore (in my area anyway).
For Cedar Sidewall Shingles, nothing holds like staples.
Old 05-08-2012, 09:17 PM   #9
Tom Struble's Avatar
Rewards Points: 2,002
what rules have changed?
Tom Struble is offline   Reply With Quote
Old 05-09-2012, 09:12 AM   #10
Cape Cod, MA
Rewards Points: 81
I dont know much about siding, but I had a question since sometime this summer I need to side a small area above my garage. Ive seen people place a strip of wood across the wooden shakes when installing. I was wondering what the purpose for this is? Im assuming it gets placed to mark where the next row gets installed?
capecodder is offline   Reply With Quote
Old 05-09-2012, 05:49 PM   #11
Rewards Points: 586
Well Tom, I guess the answer would be none, since in 1923 there were no rules yet (out West anyway).
Tom Struble (05-11-2012)
Old 05-09-2012, 06:29 PM   #12
staples definitley have holding power in sheathing but severely lacks in shear strenght, they dont keep the plywood for racking.
for roofing they dont have the holding power on asphalt shingles themselves as their isnt enough surface contact to keep the shingle from blowing off
as for sidewall shingles.. ive torn off 100's of squares of cedar off of homes and the nails hold fine if its nailed to t&g boards, now if its osb thats a totally different story
Old 05-10-2012, 06:00 AM   #13
"Old" Newbie
Rewards Points: 177
Nails or Staples
capecodder,
When I did the siding on our house I'd snap a chalk line for the next course then tack a 1X1/2" strip to the line. That way I could just set the shingle on the ledge and staple it in place. Much easier and quicker than trying to eyeball the bottom edge to the line.
RCrosby257 is offline   Reply With Quote
Old 05-10-2012, 06:33 AM   #14
Rewards Points: 586
Originally Posted by RCrosby257 View Post
capecodder,
I've never been a fan of that method. Even though it may make it easier for some to maintain a straight line your "tack" still leaves a holes in the siding.
Even if the holes don't penetrate the weather barrier there still visible and shouldn't be there.
I snap lines using "white" chalk and hold the shingle just slightly below that line.
To each there own I guess.
Old 05-10-2012, 07:27 AM   #15
Cape Cod, MA
Rewards Points: 81
That is kind of what I didnt want, to have small holes where the strip is temporarily fastened. I will try the chalk line method. As far as the shakes, should they be installed right up against the trim or should i leave a small gap for expansion?
Thanks!
Need to restore faded cedar siding on ranch house Jimigunne Painting 1 02-23-2010 12:55 AM
Preventing rot in cedar siding.. observations and questions before paint 240sx4u Painting 3 11-03-2008 07:42 AM
Painting Cupped Cedar Siding Wobbly Painting 10 09-17-2008 09:51 AM
Cedar siding my best option? TheNiceGuy Building & Construction 8 09-15-2008 06:44 AM
Exterior Cedar Siding - Products & Procedures? chitown55 Painting 9 09-15-2007 05:54 AM
