How To Install Belgian Block? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-15-2007, 02:48 PM   #1
Rewards Points: 79
How to install belgian block?
I'm not sure if I'm in the right forum to ask this, please point me in the right direction if I'm not.
I want to put belgian block around my driveway. I have the block but I'm not 100% sure how to install it.
As near as I can figure I have to dig a shallow trench and fill it with cement. How deep should this be though, I'd imagine not very. Then set the block in the wet cement, about an inch down if that should do it right? With that done take a trowel and throw a little cement between the block and smooth it using the trowel for a square edge or your finger for a concave edge. What kind of cement do I use though and do I need to add morter?
Tmb9862 is offline   Reply With Quote
Old 04-15-2007, 10:01 PM   #2
Rewards Points: 5,336
12" concrete mix in lower NY for the base. A mortar mix for the joints. Depth is up to you. But I put mine a little below the surface for looks.
Ron
Old 09-19-2008, 04:50 PM   #3
can you pour the concrete directly in the trench, and how do you keep
the height the same on the block all way to the end .
corey101 is offline   Reply With Quote
Bird Block Soffit replacement options? Heather WA Roofing/Siding 4 02-25-2011 10:06 AM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 09:05 PM
Concrete block - bond pattern tvoltz Building & Construction 1 06-11-2007 06:36 PM
