Old 10-04-2011, 09:15 AM   #1
how to install attic ladder
full description on how to install my attic ladder. is it safe to cut two joices under rafters to make room to install it?
Eastman is offline   Reply With Quote
Old 10-04-2011, 09:23 AM   #2
"Nail-Bender"
Welcome to "DIY"!
Not enough info.
Post some pictures.
rossfingal
rossfingal is offline   Reply With Quote
Old 10-04-2011, 11:09 AM   #3
Is this wire Hot?
Oh-Fudge's Avatar
Pheww! I just installed one of those baby's by myself and let me tell you it was not fun. And I was just replacing an old ladder so the opening was already there. To my knowledge these are made so that you only have to cut one joist to make the opening, unless you have 12" oc joists for some reason. Then frame in the cut joist sort of like you frame in a window opening on a vertical wall.
Oh-Fudge is offline   Reply With Quote
Old 10-04-2011, 06:06 PM   #4
Too Old
You are confusing me (which is easy) one says cut 2 joices, another says cut 1 joist. I say do not cut any joists unless you know what you are doing, What is your ceiling joist spacing?
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 10-04-2011, 06:48 PM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
My hatch is 16x16. They cut a hole in the rock-lathe in the ceiling, between the rafters, and put in a scuttle port that is just large enough for my skinny body at 207-212 lbs to get through. My dad is a little larger than I am, and he can just barely get up there.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 10-04-2011, 06:56 PM   #6
Framing Contractor
Pretty sure code says 20 " wide minimum. Whenever we have ceiling joists 16" oc, we plan it out and double up accordingly.
sixeightten is offline   Reply With Quote
Old 10-04-2011, 07:09 PM   #7
gregzoll's Avatar
We are talking about a house built back in 1937. Codes have changed since my place was built. It is actually 16x20 for the scuttle going up into my attic space (just measured, before was a rough guesstimate).
Old 10-04-2011, 08:09 PM   #8
STAFF
BigJim's Avatar
Unless they are making the pull downs different the rough opening should be 25 1/2" wide by 54 1/2" long. You will need to run a header at the front of the opening and at the foot of the opening and install a 2X what ever your ceiling joist are parallel to the ceiling joist that your header butts into, but be sure it is 25 1/2" in the clear.
If you have help it will be a lot easier than if you install by yourself. If you plan to install by yourself just post and let us know and we can tell you how to do that.
You will need shims and nails and 3 inch screws. Once the pull down is in place nail and screw the head piece to the header. Shim each side with the pull down closed to get your margins right on each side. Shim, nail and screw at the pivot plates, shim nail and screw at the foot. Open the pull down all the way with the ladder all the way extended. Fold the first joint of the ladder that rests on the floor, then push down on the rest of the ladder to be sure it is down as far as it go. Measure from the first joint to the floor and mark the folded part where it touches the floor, cut at an angle.
Close the unit up and run your trim, there ya go.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 10-05-2011, 09:38 AM   #9
Is this wire Hot?
Oh-Fudge's Avatar
jiju, excellent description, but I wonder if the original poster didn't get instructions with his ladder? Mine had detailed instructions. Yes, 2 people makes it much easier because you have to be in the attic to put in the shims and screws. There are ways of doing it alone, I put up temporary braces under the joists to hold the ladder framework up and I worked beside it standing on a stepladder to put in the shims and screws. Not to say that was easy, though!
The Following User Says Thank You to Oh-Fudge For This Useful Post:
gregzoll (10-05-2011)
Old 10-05-2011, 10:36 AM   #10
STAFF
BigJim's Avatar
I was going to write out how I installed by myself but I am just too lazy to do that unless it is necessary.
Jim
Can I mount a window A/C into the wall, exhausting to the attic? Greg2230 HVAC 2 06-01-2010 09:56 PM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 08:46 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
How much opening space lost to attic ladder? dweeter Carpentry 6 12-05-2009 02:54 PM
Furnace install in attic - Duct configuration hartkem HVAC 6 11-08-2008 06:46 PM
