How To Help Support A 3/4 Cut Joist ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-23-2014, 06:53 AM   #1
Rewards Points: 14
How to help support a 3/4 cut Joist ?
I am putting down plywood in my attic to add storage space. I came a cross a piece of wood nailed from the ceiling beam to the joist. Once I as sure it wasn't supporting anything I took it out. As soon looked at the joist I could see it was cut 3/4 the way down. How can I reinforce the joist and still put down my plywood?
Ktully1973 is offline   Reply With Quote
Old 05-23-2014, 07:14 AM   #2
Rewards Points: 13,986
Are these trusses, or built on site rafters?
What's the width and span of these joist?
Attics need to prengineered if they where meant for storage, most where never meant to be top loaded.
Top load, and the ceilings going to start sagging, and there's going to be plaster or drywall issues.
Can you see why this joist was cut? Attic stairs, vent added ECT.?
Old 05-23-2014, 08:34 AM   #3
Rewards Points: 14
The trusses or joist run front to back across the house. I have no idea why it was cut. The access point is in a bedroom closet 4ft away. I have a exhaust fan for my bathroom, but it is 10 ft from the cut.
Old 05-23-2014, 10:04 PM   #4
Msradell's Avatar
Rewards Points: 262
Can you post a picture to show us what it looks like? What is the dimension of the rafter that is cut, 2x4, 2x6, or ?
Msradell is offline   Reply With Quote
Single Rim Joist Rotted - Support? kromc5 Building & Construction 15 05-11-2014 10:23 AM
Please help! How to add floor joist to re support floor Spm8d6 Remodeling 9 03-27-2014 09:48 PM
Hanging a beam in the attic for joist support tarnishd Building & Construction 23 10-16-2012 02:09 PM
How would you support pipe in existing joist space? wease Plumbing 18 02-06-2011 05:20 PM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 09:15 AM
