-   -   How to have a temp driveway and plan for the future? (http://www.diychatroom.com/f19/how-have-temp-driveway-plan-future-81233/)
luvdairish 09-12-2010 11:32 AM
Right now I have a small asphalt driveway and a small rock driveway next to it. In the future I want to do pavers and make one BIG driveway. BUT for now I want something that joins both drives together.
Can I cover the asphalt with stone and add more stone to make a big temp driveway? Then when I'm ready for pavers in the future, I can put additional base (sand or something) over all the stone to make a nice foundation for the pavers.
My goal is to eliminate tearing up the asphalt.
thanks for the help
Aggie67 09-12-2010 08:36 PM
A couple things. In Jersey, if you're going to expand your driveway, you need to submit an application to the zoning department. Regardless of what the design is. It's a long story, but the short version is that New Jersey is particular in how much impervious cover sits on a property. And since every town is subject to the site development regs (and almost every town has its own ordinances), you need to let the town's zoning department know the particulars (square feet of existing imperv, planned pervious/impervious, etc). Call the zoning department and let them know what you want to do, and they'll let you know what to do. One note, sometimes the folks in the office have a zillion things going on, and when they describe steps, it sometimes comes out sounding like the super-fast rapid-fire fine print in auto dealer radio commercials. If it does, try to understand that they're probably multi-tasking, and have them repeat it slower.
As for leaving the asphalt under half of the stone driveway, and putting sand and pavers on top, I don't think that's a wise choice. It wouldn't be wise even if the whole thing started out as asphalt. Pavers require edge restraints, otherwise they'll spread out and look horrible. A properly designed paver driveway will have a bit of excavation, geo fabric (in certain cases), a proper recessed gravel base, edge restraints, sand bedding, etc. I think you're setting yourself up for disappointment if your goal is leaving the asphalt there.
itsreallyconc 09-13-2010 06:37 AM
just for the records - pervious conc IS pervious - pavers are not !
as ag sez, you might get away w/o tearing up the d/w in warren cty but not likely anywhere else,,, why not do it right the 1st time ?
Bondo 09-13-2010 06:43 AM
Ayuh,... 2" of stone,... then 2" of sand,... then 2, 1/2" pavers,..?? That's gonna be 1 Tall driveway...
Is the driveway sunken enough for the added height,..??
