How Hard To Replace Window Screens? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-21-2008, 06:36 PM   #1
How hard to replace window screens?
How easy or hard is it to replace window screens? I've never done it before, but I'm pretty handy.
TomBrooklyn is offline   Reply With Quote
Old 04-21-2008, 08:47 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,286
If you're talking about just replacing the screen portion of a storm window then HD has everything you need. All you need is the screen, spline, and the tool. It's pretty easy just don't make the screen so tight that the frame bows in.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 04-22-2008, 10:14 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Best way is to clamp the frame down on a flat surface. Make sure your frame is square. It's real easy to pull a light frame out of square when you roll the spline in. Lay the screening on top and square one edge. Roll a groove in the screening where it goes into the frame. Then roll the spline into the groove. Hold the screen fabric square with just a little tension and run down one side using the same process. Complete the remaining sides. If it is a large screen, be careful that you don't pull the side rails in when you roll the spline in. You want enough tension to keep the fabric taut, but not so much that you pull the frame out of square or into an hourglass shape. You'll need a spline roller. A dull striaghtblade screwdriver to start the spline and finish the corners. Trim the excess fabric with a utility knife. For large screens, I sometimes cut a piece of 1/4" lattice as a spacer for the center.
Old 01-04-2009, 02:19 AM   #4
OK. Thanks. I'll give it a go.
=Tom
Old 01-04-2009, 10:03 AM   #5
If you have anderson windows, It may have aluminum spline & alum screen, both of which are a pain to redo. Use fiberglass if possible.
butlersprints is offline   Reply With Quote
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 07:19 AM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 03:57 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
How hard is it to replace linoleum? Alan Flooring 5 03-01-2007 10:52 PM
Removing/replacing window screens gt2003 Building & Construction 5 09-21-2005 06:51 AM
