How To Get Sheet Metal Bent? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 06:53 PM   #1
Rewards Points: 682
How to get sheet metal bent?
I have two sections of sheet metal (2' by 3') that I want cut in half and the edges bent up 1/2". But I have worked with sheet metal before and know it is almost impossible to do right by hand.
Are there shops out there that will do small jobs like this? And how much will it cost? I'm worried its too small a job and no one wants to do it.
darsunt is offline   Reply With Quote
Old 12-08-2009, 07:16 PM   #2
Thumbs up
I haven't checked lately. But not so long ago, there were sheet metal shops who, in addition to fabricating ducts would do custom work for a nominal fee. But I believe you can do your project by yourself. If you have a vice attached to a workbench! (No matter what) Don't Drink and Drive, ever!!!
spark plug is offline   Reply With Quote
Old 12-08-2009, 07:29 PM   #3
Household Handyman
Rewards Points: 1,408
Depending on the thickness of your sheet metal. Do you have a skill-saw? Do you have or can get a 2x4 longer than your sheet metal? IF so, then you can bend the edges as you want. With a 2x4 longer than the metal to be bent, use your skill saw to cut a slot through the length of the board, just a little longer than the piece of metal to be bent. Place the metal into the slot to the point where you want to bend it, then bend it to the angle you want it. The slot may not be as tight as you like, and the bent edge may not be as sharp as you want, but it works. Good Luck, David
Old 12-08-2009, 07:32 PM   #4
ArmchairDIY's Avatar
Depending on how heavy a gauge it is a HVAC shop may do it. Otherwise a welding or metal working shop should have a break to bend it.
"It looked good on paper, but paper is funny that way"
Time to Get Up Out of Your Chair and Do it Yourself! ArmchairDIY.com
ArmchairDIY is offline   Reply With Quote
Old 12-09-2009, 03:55 AM   #5
Too Short? Cut it Again!
One of my HVAC suppliers is pretty cooperative with this sort of thing if I give them time and don't nag them. They are more than reasonable. I had them make several drain pans for an indoor garden and they turned out great.
Old 12-09-2009, 05:25 AM   #6
Rewards Points: 352
Harbor Freight has a small metal brake (18") that does up to 16 ga. for $35. This link list other brakes that ar pretty inexpensive.
It a tool you think you don't need to you have one.
Rege
RegeSullivan is online now   Reply With Quote
Old 12-22-2009, 12:09 AM   #7
Rewards Points: 682
That workbench vice works much better than I thought. I guess its the grip the vice has on both sides of the metal. What
Thanks spark plug
Old 12-22-2009, 12:59 PM   #8
Smile
Thanks spark plug
Glad to help. I've tampered with many things in my life (only legal ones)
Best way to seal sheet metal to wood zootjeff HVAC 1 09-10-2009 07:06 AM
Cutting in Bubbagump Painting 21 11-04-2008 09:23 PM
Tape vs. Sheet metal screws alvanos HVAC 7 03-25-2008 01:26 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
