How To Get Rid Of A Bathroom Window Above The Tub - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 12:56 PM   #1
how to get rid of a bathroom window above the tub
i have a older bungalow .the bathroom is 7 ft square along my west wall is a tub with a window above it i want to put in a walk in shower how do i get rid of the window thanks by the waymy house is block and stucko with steel siding over the stucko and block
yamaha05 is offline   Reply With Quote
Old 02-17-2012, 03:18 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Remove window, frame in, insulate, sheetrock inside, house-wrap and replace metal panel(s) outside, install shower enclosure.
titanoman is offline   Reply With Quote
Old 02-17-2012, 03:27 PM   #3
Rewards Points: 13,748
May be stuck with that window. In order to remove the siding at least the top row is going to get distroyed trying to pry it off. It's all going to have to come off to below the window in order to blend it back in once the window is gone.
Sure it's steel? More commonly it's aluminum. Check it with a magnet.
Steel is next to impossible to find, aluminum is still avalible but still hard to find.
Much easyer to remove it and go back with vinly siding instead. Just find one that matches.
Advice on replacing Bathroom window (w/pics) jasesun23 Windows and Doors 16 02-19-2012 12:40 AM
bathroom has no window Rose LaFlamme Building & Construction 4 10-30-2011 01:56 AM
replacement window for a bathroom Joan Garten Kitchen & Bath Remodeling 2 07-12-2010 06:10 AM
where to put the bathroom window debd Remodeling 3 02-04-2010 11:05 PM
Bathroom ventilation / window privacy issue Michael Thomas General DIY Discussions 10 05-26-2009 09:09 AM
