How To Get This "3D" Scattered Tile Effect? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 12:58 PM   #1
How to Get This "3D" Scattered Tile Effect?
Any tips on how to achieve this effect (assuming only single depth availability of tile/stone, or is that the only reasonable way?)? This is for a powder room wall.
Thanks in advance for any tips,
99
99altrade is offline   Reply With Quote
Old 04-11-2011, 01:51 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I've seen this type of tile on the Home Improvement type shows. If I recall correctly, they are produced in sheets (like mosaic tile or listellos) with depth differences built in. If you look closely, you can see a repeating pattern every third row.
Creating this yourself sounds like a whole lot of frustrating work. If you're determined, a rectified tile would be your best bet.
Edited to add: Don't know where you got the pic, but perhaps you could backtrack to find a manufacturer?
BTW, not plugging it, but Norstone makes something similar in stone.
Old 04-11-2011, 02:30 PM   #3
Thanks for your reply I've used the split-faced travertine panels so am familiar with the multiple tile on panel, though I thought these looked more like larger individually installed tiles.
I'm guessing now that you are probably right . Thanks for the reply.
Subfloor and Porcelain tile prep sugarhousemama Flooring 4 12-03-2010 07:47 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
3-D tile effect realtor4u General DIY Discussions 5 04-04-2009 01:45 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
