How To Frame Treads And Risers For Inside Stair Run. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2013, 06:12 PM   #1
How to frame treads and risers for inside stair run.
I've got 2 stair runs in my townhouse. I'm replacing the laminate on both of them, and it's easier to replace the whole tread and riser than to try and get the laminate off and grind down all of the glue. The stringers are cut with 9 1/2" where the tread sits.
One of the stairs will have carpet, and the other will have new laminate. Do I need to frame a nose on the treads for the laminate? For the carpet? If no nose, should the treads overlap the riser, or vice versa?
I live in Vancouver, BC.
fdiddy is offline   Reply With Quote
Old 10-21-2013, 11:38 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
You don't frame a nosing in. You pick a laminate that has a matching nose profile. As for the carpet stairs, its all aesthetics. I personally think carpet looks better with an overhang over the riser. It also allows a hidden place to staple the carpet in place.
iminaquagmire is offline   Reply With Quote
Old 10-21-2013, 11:43 PM   #3
The reason I'm asking is because the treads I took out extended past the rise and created a nose. So when I put new treads in, I'll overhang the treads for the carpet, and just square the treads for the laminate.
White Stair Risers Paint ? ( 17 ) deck hand Painting 6 02-05-2013 11:12 PM
Raising & replacing stair treads zakany Flooring 5 11-29-2012 11:51 AM
product to cover stair risers karen1 Remodeling 3 08-26-2012 01:39 PM
replaced stair treads dhungy Flooring 5 06-20-2012 11:21 AM
Stair Tread and Risers tuchodi Flooring 0 08-03-2011 09:38 AM
