How To Frame A Sideways Stud Without Having A Lip - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-09-2010, 09:53 PM   #1
Rewards Points: 105
How to Frame a sideways stud without having a lip
Okay, I have a newbie question I'm embarrased I've never run into.
I have a very small room closet that I'm framing, and I have a small corner around a pole that takes up too much room. I don't want to lose another two inches of space by putting the studs the standard parallel way on the side closest to the doorway.
Short of ripping a stud as a bottom and top plate, is there another way to frame it so that I can put the vertical stud sideways so it takes up a little less space.
When I lay down a regular stud and then put the sideways stud on the outside, the outside corner looks good, but the inside part near the pole has an inch or more (the difference between the depth of a piece of wood and it's width) of wood visible at the top and bottom.
jdm001 is offline   Reply With Quote
Old 07-10-2010, 08:42 AM   #2
Rewards Points: 5,336
Use a 2x2 as the bottom plate.
What's the issue with ripping a piece of wood down to a 2x2? This is a simple solution to the problem.
Ron
Old 07-10-2010, 08:06 PM   #3
Rewards Points: 105
If I rip a 2x4 it'll split securing the stud plate to the cement unless i pre drill everything (I dont have a ramset), which would take a lot longer.
I'll try the 2x2 though, maybe with its pressured sides it wont split.
Thanks for your help!
Old 07-10-2010, 08:48 PM   #4
If you need to drill pilot holes, drill pilot holes. You act as though doing the correct procedures is more effort then you think is worth your time.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Willie T (07-10-2010)
Old 07-10-2010, 09:03 PM   #5
Old School
Willie T's Avatar
You know how people say, "They just don't build 'em like they used to."? It's because in the days of yore, builders just accepted that there was a right way to go ahead and build something......... and then there were substandard shortcuts.
It only costs a nickel more to go First-Class............ but it DOES require spending those five pennies.
Willie T
Old 07-11-2010, 12:49 PM   #6
Rewards Points: 105
Oh I'm not worried about the time it'll take, I was meaning that I thought there would be a better way... IE For contractors.
I only have to frame around a small pole which is less than 3 feet of space I'll need to worry about. An extra ten minutes.
I was just thinking that if I had to do a long run like that, which I'm sure has to happen sometimes, that a contractor might have had a different way.
I'm going to use the 2x2 and pre drill everything. Thanks again for your help!
moving a load bearing stud Tonglebeak Building & Construction 34 07-07-2010 12:32 PM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 01:11 AM
Is it safe to remove this stud? lofar Remodeling 4 06-16-2009 11:22 PM
Exterior wood door frame on concrete floor RosenKen Building & Construction 3 06-05-2009 02:23 PM
Please, help with sheathing and stud placement Mrmusic Building & Construction 2 09-10-2008 04:52 PM
