How To Frame, Install Plumbing And Shower Over A Concrete Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 10:00 PM   #1
How to frame, install plumbing and shower over a concrete slab
Installing a shower in the basement. Due to the ground water table levels, cutting into the concrete slab is NOT an option. I was thinking on using a sani-flush system. I am guessing I will have to frame out some sort of pedestal to raise the shower pan high enough to put in the trap, and have it drain into the sani-flush tank. I dont know how hi to make this pedestal, etc. Anyone ever install this type of setup before?
nflravens is offline   Reply With Quote
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 04:06 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Shower Pan and concrete slab plumbing LTempleton Kitchen & Bath Remodeling 2 08-08-2009 12:47 PM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 07:37 PM
Ant's through slab plumbing aace Pest Control 4 02-13-2008 03:48 PM
