How To Frame A Flat Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 01:22 PM   #1
Rewards Points: 640
how to frame a flat wall?
How do you go about framing a wall so when its drywalled it has very few bumps in it or differences in height?
I know when you pick boards you are suppose to find the ones with the least twist and straight as you can on the front edge and side edge so you don't have bulges in you walls... then when you put the studs up you put the crowns all going one way... but even with this, I seem to have problems with drywall having some valleys or high spots in it... not major, say like an 1/8th an inch at most, but when you put stained trim on it stands out as a gap...
any tips, suggestions, or articles I can read to try to improve my skill?
also does putting construction adhesive on the studs before drywalling help any with the bumps to flatten out the low spots or anything? thanks
BlueBSH is offline   Reply With Quote
Old 05-17-2011, 02:21 PM   #2
Tizzer's Avatar
Rewards Points: 460
A nail driven into the end(corner)stud of each wall. String line held out the thickness of block you'll use to gauge with, run across the middle of the wall. Depending on whether the stud needs to be pulled or pushed,make a saw cut maybe a 1/4 way through the stud.
Put a shim in the saw cut held in with an 8 penny nail. If it couldn't be straightened enough that way, we'd replace the stud.
That's how we did it anyway.
Tizzer is offline   Reply With Quote
Old 05-17-2011, 02:24 PM   #3
Rewards Points: 640
well the wall im going to make isn't built yet, I'm just looking for tips to get it as straight as possible while its being framed, the other walls are 100% done
Old 05-17-2011, 02:29 PM   #4
Framing Contractor
Rewards Points: 120
Do everything that you said, and make sure to snap a line at the floor and the ceiling. If the wall is straight to the line, the only other thing you will deal with is the crowns. Another option would be to use metal studs. No crowns, twists, splits, etc to ever deal with.
sixeightten is offline   Reply With Quote
Old 05-17-2011, 02:31 PM   #5
Rewards Points: 640
metal isn't a go for me, I don't like working with it... sure its faster and lighter... but I want to stick with wood for this
I guess my big thing is how to deal with crowns.... should they face out or in if its an exterior wall? does it really matter as long as they are all going the same way?
Old 05-17-2011, 02:37 PM   #6
Framing Contractor
Rewards Points: 120
As long as they all go the same way it doesn't matter. If you are really wanting to keep it nice, try this. Number every perfect stud a #1. Number all the decent ones a #2. Number all the other usable crowns as a #3. Now use the #1's at the ends, and make sure you never have a #1 next to a #3. This will make everything gradual. I have never done this, but someone mentioned it once. For only one wall it wouldn't take that long I guess.
Old 05-17-2011, 03:27 PM   #7
kwikfishron's Avatar
Rewards Points: 618
I think your over thinking this a bit Blue. Pick out some studs and build the wall. You can check the wall with a straight edge, Tizzer gave you one method of straightening studs. The sheetrock will float over minor imperfections.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
AndyGump (05-17-2011)
Old 05-17-2011, 07:23 PM   #8
Rewards Points: 640
I guess thats what happens when you want to make sure you are doing stuff right and trying to be doing if perfectly, I know the pros cant even be perfect, just wondering how they do it
Old 05-17-2011, 09:44 PM   #9
Most of them around here throw a stud down and however it land its good.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 05-18-2011, 06:39 AM   #10
Stay-at-home GC
I'm afraid I have to disagree on this one. Your stud crowns on exterior walls should face out and on interior walls, they should face away from the kitchen.
The reason is for setting wall cabinets. If the stud is crowned away from the cabinet, you should only have to shim one side (usually the bottom). However, if the studs are crowned in to the cabinets, you end up with a tall wall cabinet that "rocks" on the crown. In the end you have to shim it top and bottom to get it plumb.
To check your walls before drywall. Walk the length of the wall with a 6 or 8' level and, holding it horizontally, try to get it to "rock" on each stud. If it rocks badly, mark the stud for repair.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
The Following User Says Thank You to CplDevilDog For This Useful Post:
mustangmike3789 (05-18-2011)
Old 05-18-2011, 06:59 AM   #11
NACE Coating Inspector
mustangmike3789's Avatar
some of the problem may be in the drywall finish work too???
mustangmike3789 is offline   Reply With Quote
Old 05-18-2011, 11:17 AM   #12
Rewards Points: 93
I used drywall shims with good results. They are 1.5" x 46" cardboards, about 1/10" in thickness. They can be easily cut with a pair of scissors. I used a 8ft level to check the studs and stapled the shims onto the studs to get everything lined up.
leungw is offline   Reply With Quote
Old 05-18-2011, 02:13 PM   #13
Framing Contractor
Rewards Points: 120
I agree with you on the kitchen. He never said he would put cabinets against it. The only reason we put the crowns out on exterior walls, is so that the wall studs don't rock while we are building the wall.
Old 05-18-2011, 02:40 PM   #14
Stay-at-home GC
Hopefully the new thing you learn today doesn't kill ya'
Crown moulding: Flat ceiling to angled wall question RP31 Carpentry 19 10-30-2012 03:18 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 01:55 PM
Joining timber frame to brick wall deyveed Building & Construction 2 10-27-2009 08:02 AM
