-   -   how to frame a deck around a bay window? (http://www.diychatroom.com/f19/how-frame-deck-around-bay-window-86716/)
tpcolson 11-14-2010 04:24 PM
There's LOT'S of examples of how to frame around a bay widow. However, NONE of the examples offer insight on how to frame around an ANGLED bay window, which, is what most bay windows are! Aside from the obvious use of skewed joist hangers, which aren't allowed with local code, how does one frame around and angled bay window and keep load ratings for the deck surface between the bay window and the "normal" frame? Thanks.
Ron6519 11-14-2010 07:24 PM
Cut the bay structure out under the window. Attach the ledger to the house and rebuild the bay to the deck.
Support as needed.
Ron
tpcolson 11-14-2010 07:42 PM
interesting...but the bay is cantilevered, and the beam sits below the top deck height. No cutting going on there...
Ron6519 11-14-2010 07:50 PM
Post a picture of the structure you have. Any bay can be restructured.
Ron
Tom Struble 11-14-2010 09:22 PM
post and girder or reframe like Ron says...you can't ledger off a cantilever
Gary in WA 11-15-2010 12:13 AM
Fig. 35, add an angled joist to cut the corner with hangers: http://www.lancova.com/deckinfo.pdf
Gary
GB Greg 11-15-2010 07:18 AM
Not sure what the rules/laws are where you're at. But couldn't you frame the deck w/ your joists sitting on top of a twin 2x beam. Locate your beam at the face of the bay, then cantilever the joists the 2' or so back to the house? Work around the bay rather than reconstruct it. I'll come up with a sketch and post it if need be.
-Greg
Joe Carola 11-15-2010 04:09 PM
That can't be true. Never heard of such a thing before.
How wide is the bay?
Bob Deb 11-20-2010 11:20 AM
Couldn't you frame around the bay window similar to how you would frame an opening in the floor for stairs? Double up on the joists adjacent to the window & connect them with another doubled up header to attach the joists in front of the window to.
Sorry for the crude sketch, but I think it'll clarify what I mean.
http://img.photobucket.com/albums/v5...otos/deck1.jpg
tpcolson 12-17-2010 11:30 AM
regarding the diagram shown in the last post, how would I attach decking material past the 2 2byX up to the window? I believe code allows 2" of decking to extend past a frame member? In my configuration, after installing the H frame around the bay, I'll have a 20" gap at the widest part of the triangle. The H Frame makes sense, I'm just wrestling with the angled frame members: I can find now skewed hangers that will work at the angles I have to work with. The simpson is only good for 40-50 and I'm at 30(L) and 60(R).
bob22 12-17-2010 04:13 PM
Just run some joists on an angle to close the space (mirror the bay window angle).
Joe Carola 12-17-2010 05:01 PM
What's the problem then? You said code won't allow skewed hangers, now the code will allow? This is normal every day framing with bays and skewed hangers. I don't understand what problem you are having.
