How To Frame For Bifold Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 01:00 PM   #1
Rewards Points: 640
how to frame for bifold door
I need to put a small utility closet around my water entrance in my basement, I dont want a full blown closet due to the space.. so I was thinking frame around it and put a bifold door, well on one side there is a wall, the other there is a window... I have 33" of space wide to work with and 3 ft from the back of the room to where I can stop framing out depth wise... I wanted to put a 24" bifold door so that would give enough room to work in the closet and get to the meter and its plumbing... one on the left end I want it to be flush with the wall (this is a frameless bifold, just drywall in this scenerio... then on the right side build a wall, and a wall on the top...
first question what do I rough it in at to do this with a 24" x 80" bifold, this is the one I want to put in
http://www.lowes.com/pd_80114-11813-...3179245&Ntt=24
Finish Opening Width (Inches)24.0
Finish Opening Height (Inches)80.0Height (Actual) (Inches)80.0Door Thickness (Inches)1.375
drywall is 1/2", have 33" to work with so that leaves me with 9" on the right side if this is flush with the perpendicular wall on the left side, but then 4" of that will be taken away from the width by the wall that goes backwards to the foundation wall... so that would leave me with a whole 4-5 inches, how would you suggest doing the framing? any other options? the space is limited... and I'd really like to enclose this so its not an eyesore in the room, thanks!
BlueBSH is offline   Reply With Quote
Old 09-14-2010, 01:55 PM   #2
Rewards Points: 640
no takers on the question? or do you need anymore information?
Old 09-14-2010, 02:34 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 402
You would frame the opening just like a regular door with 2X4s and you can use 2X4s for the header as there is no weight to worry about. I assume you are getting the bifold doors with a track at top and pivot on the floor but if you are going to use hinged doors beware as the sheet rock will not work as a base for the hinges. Once you have the doors you will see easily how everything must work.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-14-2010, 03:05 PM   #4
Rewards Points: 640
Yeah, I'm going to get one that has the top track and bottom pivot point, but when framing for a 24" door, what is the width you frame for when it has no real frame, jus drywall? is it the width plus a little bit? or how would you calculate that?
Old 09-14-2010, 04:50 PM   #5
jlhaslip's Avatar
Rewards Points: 2,188
Wood half jambs? or wood full jambs? or drywall jambs?
Calculate the width of the door plus 2 inches for full jambs, width plus an inch for the others.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
BigJim (09-14-2010)
Old 09-21-2010, 01:36 PM   #6
Rewards Points: 640
drywall jambs in this instance... what about height? the door says 77" should I still make it 80" finished? or should there be less of a gap on the top and bottom?
Old 09-21-2010, 02:37 PM   #7
Tizzer's Avatar
Rewards Points: 460
25 inches finish. No jambs, just sheetrock to sheetrock.
Height: 80" finish. I'm measuring mine but the door itself measures 78 1/2".
Those wooden ones from Lowes fits these openings. Figure for carpet or vinyl too. You have some hgt. adjustment on those doors.
Tizzer is offline   Reply With Quote
Old 09-21-2010, 02:52 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 402
If your bifolds have a track you will need to allow for wood at the top to fasten your track to or recess the track into the rock. If your bifolds have the pivots in the top and bottom you will need to allow for a wooden support for the top swivel or cut out the sheet rock and allow the pivot to recess unto the rock. If your bifolds are hinged on the side you will need to allow for wood to mount the hinges to as sheet rock won't work.
Jim
exterior door frame size and rough opening kevincw01 Building & Construction 3 06-06-2010 08:26 AM
steel door sticking in frame bruce_hyman Building & Construction 10 12-20-2008 07:17 AM
How bad did i screw up my door frame? SANCSANC Painting 1 12-17-2008 04:15 PM
How to Frame a Door under Soffit xlr8tn Building & Construction 3 01-17-2008 06:22 PM
Parallelagram Door Frame intuovultu Building & Construction 1 09-07-2007 11:02 AM
