How To Frame In-between Joists For Drywall? (quick Q) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-29-2008, 04:06 PM   #1
Rewards Points: 324
How to frame in-between joists for drywall? (quick Q)
Ok, how do you guys frame this area (towards the left of the pic) to support the ends of ceiling drywall pieces? The top plate on the load bearing wall in the left of the picture is level with the bottom of the floor joist.
Without some sort of framing I wont have anything to screw the end of the sheetrock to.
Thanks.
tigerbalm2424 is offline   Reply With Quote
Old 01-29-2008, 05:54 PM   #2
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
Thanks.
That area usually has a piece of 2x material nailed down to the top plate,and sticking over the edge at least 1".
Should have been in before the foam.
oldfrt is offline   Reply With Quote
Old 01-29-2008, 06:31 PM   #3
Rewards Points: 324
Thanks. I did that on a couple other walls already but figured there was an easier way. Im using a pneumatic nailer and it doesnt fit up in-between the joists so It would have to be done by hand(guess I figured there was a better way with a nailer).
P.S. Its fiberglass, not foam.
Old 01-29-2008, 06:39 PM   #4
Neanderthal Woodworker
woodman51jfk's Avatar
......you could always hold the deadman in place & run 3" drywall screws into it from the open side......lots easier than trying to nail in confined space.......unless you get ya one of those pneumatic "palm nailers".....saw one over at Harbor Freight for about $20
woodman51jfk is offline   Reply With Quote
Old 01-29-2008, 07:51 PM   #5
Rewards Points: 5,336
Remove the insulation and install a 2x6. Screw through the bottom of the double plate with 4" screws.
Ron
Old 01-30-2008, 03:52 PM   #6
Cut nailers to run perpendicular to the floor joist so that the other end rests on the top of the double plate. Put a nailer in every 16-24" , whatever distance you want to have between screws when you drywall. Screw up through the double plate like Ron said and toe nail the other end into the joist.
DIY4EVER is offline   Reply With Quote
Old 01-31-2008, 06:05 PM   #7
You might be able to use something like the nailer
http://www.thenailer.com/
dk_99 is offline   Reply With Quote
Old 02-02-2008, 06:43 PM   #8
Rewards Points: 150
The Nailer works really good for things like that.
kgphoto is offline   Reply With Quote
garage ceiling joists josh123 Carpentry 6 07-14-2009 11:07 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 07:57 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 05:29 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 08:50 PM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-13-2005 11:16 PM
