Old 01-13-2013, 03:11 PM   #1
How to frame around the windows in the basement and flooring
Hi just curious how do i frame around basement windows. I am building a craft room. Also what about flooring? No problems with water so do I put a sub flooring or floating flooring first or what. I want to put carpet or is that not a good idea? First time project.
Thanks for any in put.
Maria
kycakelady is offline   Reply With Quote
Old 01-13-2013, 03:17 PM   #2
Got a picture?
May want to check out some of these.
http://www.bing.com/videos/search?q=...ideo&FORM=VDRE
I would not use laminite in a basement.
I'd want a padding with a built in vaper barrier if your going with carpet.
Old 01-14-2013, 12:38 AM   #3
Do you have a slab, I assume, in the basement? Have you taped a 1' square sheet of poly (plastic sheet) onto the floor and observed over a few days that no water is condensing on it? Is the floor cold now?
The Following User Says Thank You to jklingel For This Useful Post:
GBrackins (01-14-2013)
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
basement flooring suggestions? jeffro83 Flooring 2 05-14-2011 01:58 PM
Basement Flooring Recommendations wtdedula Flooring 2 10-19-2009 11:48 AM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 08:06 PM
Basement Flooring ... njchan Flooring 3 03-19-2008 07:02 PM
