Old 11-24-2010, 09:16 PM   #1
How to frame around basement window near sump
How would you frame the window and sump pit in the attached picture
casnj is offline   Reply With Quote
Old 11-25-2010, 10:16 AM   #2
I"d make a closet in that corner that would have the window within it; otherwise, it looks like you'd have to have an angled wall between the sump and the window wall and that would not only look odd but may make it difficult when you need to replace the sump pump.
bob22 is offline   Reply With Quote
Old 11-25-2010, 11:42 AM   #3
really want the window in the room. I was thinking of the angled wall but it wont look right. My last option is to have a raised box area over the pump
Old 11-25-2010, 10:08 PM   #4
I have a raised box thing in my basement for a drain cleanout - I made it waist-height and covered the top with laminated pine instead of drywall. I routered the edge of the pine, leaving an overhang, and finished off the sides just below the pine with quarter round. It doubles as a table-top for a vase, pictures, or to set drinks on.
Squishy is offline   Reply With Quote
Old 11-27-2010, 05:59 PM   #5
Pro
that isn't much window at all anyway
DarKarvin is offline   Reply With Quote
how to frame a deck around a bay window? tpcolson Building & Construction 11 12-17-2010 06:01 PM
Retrofit window - void between vinyl and alum frame?? pcl586 Remodeling 13 05-20-2010 07:24 PM
framing basement window ant1929 Remodeling 3 01-15-2010 03:53 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 12:15 PM
