How Flat Is Plate Glass? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-02-2009, 11:01 PM   #1
How flat is plate glass?
I need a very flat glass as a base for sharpening blades and was hoping plate glass would fit the bill. I know that float glass is very flat so how does plate glass compare to it? Between a 3/16" thick float glass and 1/4" plate glass which tends to cost more? Thanks.
applebuilder is offline   Reply With Quote
Old 09-02-2009, 11:27 PM   #2
Registered User
Termite's Avatar
I've used 1/2" float glass with good success. Never tried plate glass.
The one thing that works better is a piece of granite. It is the flattest thing you'll ever find, and it will not deflect or contour to the table it is on no matter how hard you press on it. If you call local granite fabricators they'll almost certainly have pieces large enough to do what you need to do. They're too small for countertops so they almost always get trashed. I called my granite guy and got a piece of "trash" granite that is 14x30"...Perfect for lapping my jointer plane and everything smaller. He even cleaned up the edges just to be nice.
The "scary sharp" system as this is called is unbeatable for ultra-sharp plane irons, chisels, etc. You do go through the wet/dry paper pretty quick though.
Old 09-02-2009, 11:51 PM   #3
Wow great tip. I avoided granite because it was so expensive but I'm definetly going to take your advise and try to find some scrap pieces, thanks alot!
Old 09-03-2009, 07:55 AM   #4
Registered User
Termite's Avatar
Check out this link. It is the website of a handplane expert, and he discusses sharpening methods in depth. Scary sharp is one of those methods. Click on "sharpening" on the right hand side.
http://www.rexmill.com/
Old 09-03-2009, 04:07 PM   #5
Thanks for the link, I just called my local granite fabricator and like you said they got plenty of scraps for the taking.
Old 09-03-2009, 04:09 PM   #6
Registered User
Termite's Avatar
Not a problem. You'll end up liking that more than glass, trust me!
Glass on greenhouse roof Flavio Building & Construction 16 07-15-2010 07:37 AM
Glass mirror over fireplace, any ideas how to install flat screen TV? dynamo Building & Construction 1 07-25-2009 09:02 AM
Help with replacing some glass shonkster Building & Construction 5 03-12-2009 05:24 PM
