How To Fix A Raised Floor Joist?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-10-2010, 11:02 AM   #1
I just pulled up some old carpet in my living room to replace with tile, and noticed that I have a floor joist that has risen and caused a crackline in the subfloor. It is not a bad spot and was not even noticable when the carpet was down, but I'm concerned that the tiles along this ridge will not settle correctly.
How do I go about fixing a raised floor joist? I'm more use to a sagging joist where all you need to do is add a lift jack in the crawl space, but have not delt with a joist board that has risen.
Any and all advise will be very much appreciated!! Thanks in advance!
2 threads on same issue merged
athenshome is offline   Reply With Quote
Old 06-10-2010, 11:34 AM   #2
kwikfishron's Avatar
Rewards Points: 394
Just cut the bump out.
kwikfishron is online now   Reply With Quote
Old 06-10-2010, 11:58 AM   #3
Is there a basement below ?
Is the house sitting on piers ?
I'd be more concerned that whatever is causing this will continue
An older house we looked at had the same issue - but worse
It was a post in the basement that was being forced up
Old 06-10-2010, 12:26 PM   #4
The foundation is a crawl space and is a standard floor system. I have not gone down and check this area yet, but I believe it should be accessible. The house was built in 1969.
Any advice on how to determine what is causing this rise?
Old 06-10-2010, 02:06 PM   #5
DIY staff
Rewards Points: 7,174
If it is just a bowed joist--Do as Kwikfishron suggested--open the subfloor to expose the joist and flatten it out with a skillsaw or power plane.
If something is pushing it up--post a picture.
Old 06-10-2010, 08:41 PM   #6
Registered User
Rewards Points: 5,492
You do know to add underlayment for tile over your subfloor............. Could be a high crown, if the only one next to normal ones. Use a straight-edge or level to determine the problem, get back to us for the solution.......
Be safe, Gary
Tags
crawl floor repairs , crawl space repairs , floor joist , floor joist repair , floor joist repairs , flooring repairs , raised floor
raised garden on septic tank Rae Landscaping & Lawn Care 4 04-27-2010 10:27 AM
How to remove old rusty raised deck nails win Carpentry 4 05-18-2009 10:30 AM
Receptacle in kitchen island raised counter backspash interplexr Electrical 1 05-16-2009 06:06 AM
Question on Raised Panel Cabinet Door orange Carpentry 2 03-13-2008 06:28 PM
Raised Panels? JFD140 Carpentry 9 09-19-2007 07:43 AM
