-   -   How to Fix a Raised Floor Joist?? (http://www.diychatroom.com/f19/how-fix-raised-floor-joist-73333/)
athenshome 06-10-2010 11:02 AM
I just pulled up some old carpet in my living room to replace with tile, and noticed that I have a floor joist that has risen and caused a crackline in the subfloor. It is not a bad spot and was not even noticable when the carpet was down, but I'm concerned that the tiles along this ridge will not settle correctly.
How do I go about fixing a raised floor joist? I'm more use to a sagging joist where all you need to do is add a lift jack in the crawl space, but have not delt with a joist board that has risen.
Any and all advise will be very much appreciated!! Thanks in advance!
2 threads on same issue merged
kwikfishron 06-10-2010 11:34 AM
199 Attachment(s)
Just cut the bump out.
Scuba_Dave 06-10-2010 11:58 AM
Is there a basement below ?
Is the house sitting on piers ?
I'd be more concerned that whatever is causing this will continue
An older house we looked at had the same issue - but worse
It was a post in the basement that was being forced up
athenshome 06-10-2010 12:26 PM
The foundation is a crawl space and is a standard floor system. I have not gone down and check this area yet, but I believe it should be accessible. The house was built in 1969.
Any advice on how to determine what is causing this rise?
oh'mike 06-10-2010 02:06 PM
If it is just a bowed joist--Do as Kwikfishron suggested--open the subfloor to expose the joist and flatten it out with a skillsaw or power plane.
If something is pushing it up--post a picture.
Gary in WA 06-10-2010 08:41 PM
You do know to add underlayment for tile over your subfloor............. Could be a high crown, if the only one next to normal ones. Use a straight-edge or level to determine the problem, get back to us for the solution.......
Be safe, Gary
