How To FIX A Leaning Deck Post - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-11-2010, 03:21 AM   #1
How to FIX a leaning Deck Post
Hi! I'm new here and not a handyman whatsoever. We were building a deck for the first time the other day and didn't level one of the posts correctly. If you look a few feet away, the post is awkwardly leaning waayyy to the left. Partly because the U bracket (with the long pole sticking down) attached on the foot of the post is not level due to not placing it correctly aligned on the drying cement and partly just because we're not cautious (we only leveled the top of the post and not the sides) . Being foolish enough, we didn't bother fixing it and just placed a diagonal bracing to strengthen it. Now... it's bugging me... the joists are all laid out and we're on the final stages of putting the floor boards... Is there still a way out of this? Can I still align the post even if all of its load are already screwed in? Do I need to pull everything apart? waaaa! Well... if that's the only way... please let me know . It's a learning experience after all. Any reply would be truly appreciated. Thanks!
CJ_cda is offline   Reply With Quote
Old 08-11-2010, 05:58 AM   #2
Rewards Points: 5,336
Post a few shots from different angles.
Ron
Old 08-11-2010, 12:24 PM   #3
Ron
I don't have a camera at the moment but I'll try to borrow one later... I hope this sketch will make up for it at the moment.
The beam and joists are all level. The deck seems sturdy enough and not shaking when jumped on.
One thing I forgot to draw is the diagonal bracing.
Old 08-11-2010, 12:27 PM   #4
kwikfishron's Avatar
Rewards Points: 1,002
Pull the nails out of the post cap to the beam and knock it over.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Willie T (08-12-2010)
Old 08-11-2010, 01:27 PM   #5
joed's Avatar
Rewards Points: 13,722
I second that suggestion.
Old 08-11-2010, 03:24 PM   #6
jlhaslip's Avatar
Rewards Points: 2,878
thirds
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 08-11-2010, 11:23 PM   #7
Thanks guys... didn't think of that... I'll try doing it.
Old 08-12-2010, 07:31 AM   #8
Not so new
12penny's Avatar
Rewards Points: 520
Unless...theres a break in the beam at that spot. Then you'll have to move the bottom.
12penny is offline   Reply With Quote
Old 08-12-2010, 08:28 AM   #9
Old School
Willie T's Avatar
If it turns out that there is a break in the beam, and you can't move the top.... and moving the bottom would take you off the metal bracket, there is a third fix I'll tell you about. Actually, even a fourth.
Post and let us know.
Willie T
Old 08-13-2010, 07:43 AM   #10
Not so new
12penny's Avatar
Rewards Points: 520
Guess he figured it out.
Old 08-13-2010, 09:04 PM   #11
Sorry guys... haven't tried it yet... It's raining hard for the past 2 days and I can't do it since our backyard is very muddy and wet... According to forecast, the weather will be sunny by Monday or Tuesday. I'll do it then. I'll let you know what happens. Thanks again!
Old 06-18-2013, 11:10 AM   #12
Rewards Points: 47
You know that the leaning post is longer than the other upright posts. It may have started the same length but is now covering a longer span since it is no longer a straight line. The shortest distance between two points is a straight line. If you can get the post knock over into an upright position then all is well. If the deck has settled or the post has swollen then you might have to shave the end to make it fit. Or, the simplest thing if the board is now out of spec is to get a new board and good luck.
jeffs55 is offline   Reply With Quote
Old 06-18-2013, 11:22 AM   #13
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Jeff,
I think he figured it out.
This post is over 2 years old........
sublime2 is offline   Reply With Quote
Old 06-18-2013, 11:25 AM   #14
Roofmaster
Rewards Points: 2,210
Originally Posted by sublime2 View Post
Jeff,
I guess Jeff sees old posts showing up Bold too, just like me. How about fixing this WebMaster?
Old 06-18-2013, 11:28 AM   #15
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
It shows up bold when there has been a reply/post to a thread.
Tags
align , deck , fix , post , problem
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 09:01 AM
6x6 Cedar post rot stanltod Carpentry 2 06-21-2009 04:54 PM
What kind of 4x4 post shoul I use for rail on my deck? renoet Carpentry 6 02-14-2009 06:57 AM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 10:16 PM
Two-Level Deck Post Question Melanie337 Carpentry 2 09-23-2007 11:34 PM
