How To Fix Garage Cross Supports? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-29-2011, 02:44 PM   #1
How to fix Garage Cross Supports?
Anyone know how to fix the problem in the pic below?
Not sure of the proper name but I'm calling them "Cross Supports".
The previous owner cut through them for the Garage door opener.
It's a single car shared garage. Wood frame on a concrete slab.
How can brace/strengthen/replace/fix this?
Any help is appreciated.
Thanks!
Majoram is offline   Reply With Quote
Old 08-29-2011, 03:22 PM   #2
Experienced
Jackofall1's Avatar
All I can say is wow!!!!!!! That is incredible.
Cut 4' lengths of 2 x 4 for the top of the joist and then lace in with 4' strips 3/4" plywood (as wide as possible), one on either side of the joist, staggered 2" screws on 6" centers.
Mark
Old 08-29-2011, 10:19 PM   #3
Rewards Points: 150
I'll echo that-WOW!. It should be against the law for some people to breathe and whoever did this is the poster boy. The garage door opener will have to come down and be installed correctly. Depending on the span, you might be able to get away with what is called an engineers fix- that's what we call it down here. You'll go 4foot on either side of the cuts with corresponding size materials on each side, like sistering both sides, glue and screw the materials together. I'd also check it to see if it has dropped any. You may have to jack it and do a full sistering the entire span.
TrapperL is offline   Reply With Quote
Old 08-31-2011, 07:42 AM   #4
How should I check if anything has dropped?
I don't think I can move the Garage door opener.
There is no space to move it higher or lower.
Hence why I need to brace the supports.
I'm open to any suggestions you may have??
Thanks both for the help!!
Old 08-31-2011, 01:59 PM   #5
Rewards Points: 1,580
There are low clearance garage door opener kits; you'll have to google them to see if you would have enough clearance between your doors and the bottom of your rafters.
bob22 is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Garage floor Tomperro Flooring 6 07-18-2011 12:30 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Garage Ventilation Question eagle09tbl HVAC 5 10-22-2009 09:24 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
