Old 05-09-2010, 11:52 PM   #1
how to fix the drywall around window frame....
Had a new set of windows put in about a year ago. Windows continued to leak whenever it rained hard. The cause of the leak was due to rotting wood around the exterior wood paneling around the windows. The wood paneling have been replaced and it is no longer leaking.
On the interior, the drywall around some parts of the window are crumbly or weak due to water seeping through previously. There is a drywall hole on a corner of the window and the inside wood paneling around one part of the window is not set firmly against the drywall; there is space between the drywall and the wood paneling (see attachments). I'm pretty much a beginner in all of this. Any easy suggestions to fix this.
Skipper1977 is offline   Reply With Quote
Old 05-10-2010, 09:46 AM   #2
Drywall contractor
Looks like mostly loose paint. Scrape all the loose stuff off. Mesh tape and first coat with setting type compound (6" knife will do). A skim (or two if needed) with regular ready mix. Sand and paint.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Retrofit window - void between vinyl and alum frame?? pcl586 Remodeling 13 05-20-2010 07:24 PM
Window Installation Questions cumak Building & Construction 0 05-05-2010 01:22 PM
removing polyurethane from a window frame and molding diy'er on LI Painting 1 11-02-2009 10:54 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 12:56 PM
